| Thread Closed |
Cubic roots |
Share Thread | Thread Tools |
| Jul13-07, 06:17 PM | #1 |
Cubic roots
Hi! Who knows:
can any cubic root like [itex]\sqrt[3]{x}[/itex] with x real be written as a form in which only square roots (real or complex) are involved? |
| Jul13-07, 06:22 PM | #2 |
Sorry, not any but every!!!
| Jul13-07, 07:49 PM | #3 |
Yes it can, but sometimes the square root have to be of an irrational number like another cubic root so while it's the square root of a real number we haven't gotten rid of cubic roots. For example we have: [tex]\sqrt[3]{2}=\sqrt{\sqrt[3]{4}}[/tex] or [tex]\sqrt[3]{-2}=\sqrt{\sqrt[3]{4}i}[/tex].
If x is nonnegative then we have a nonnegative real [tex]y=\sqrt[3]{x^2}[/tex]. Clearly [tex]x^2[/tex] exists for all real x and is itself a real nonnegative number. Similarly every nonnegative real number have a nonnegative real cubic root, so [tex]\sqrt[3]{x^2}[/tex] also exists and is a nonnegative real. The square root of y also exist since all real nonnegative numbers have a real nonnegative square root. [tex]\sqrt{y}=\sqrt[2*3]{x^2}=\sqrt[3]{x}[/tex] So the square root of y exists for all nonnegative x and it's equal to the cubic root of x. For negative x we have a positive real number z such that: x = -1z So: [tex]\sqrt[3]{x}=\sqrt[3]{-1z}=\sqrt[3]{-1}\sqrt{z}=-\sqrt[3]{z}[/tex] Since z is a nonnegative real number we know that we can write its cubic root as the square root of a real number. Let [tex]\sqrt{y}=\sqrt[3]{z}[/tex], then we have: [tex]-\sqrt[3]{z} = \sqrt{i} \sqrt{y} = \sqrt{yi}[/tex] So for all negative x we can write its cubic root as the square root of a pure imaginary number. |
| Jul14-07, 05:58 AM | #4 |
Cubic roots
Yes, obviously, if a is any real number, I can define y to be a2 and then say [itex]a= \sqrt{y}[/itex]. I don't think that was what edgo meant.
In general, a cube root cannot be written in a form involving only square roots and rational numbers. That is because any number written in that form must be algebraic of order a power of two while any cuberoot is obviously algebraic of order 3. |
| Jul14-07, 02:11 PM | #5 |
Recognitions:
the proof halls is giving depends on the fact that there is a certain vector space associated to the root, and the dimension of that vector space equals the degree of the polynomial, namely 3. Moreover, if the expresion is writtena s a composition, the degrees are multiplicative, so if a square root were involved the product would be even, a contradiction. this is elementary field theory, and is based on the fact that the k vector space
k[X]/(f(X)) where f is a polynomial of degree d, has k dimension d. |
| Jul14-07, 06:53 PM | #6 |
Three times: Thank you.
I'm not (yet?) familiar with the Galois theory. Then, I assumed that the cubic roots which are involved in the solution - via the Cardano or Harriot algorithms - of cubic equations were there because the algorithm introduced them. This not being so has the consequence that in the value of cos x etc. in general cubic roots are involved (since you can also solve most cubic equations with a goniometric algorithm). Am I right? |
| Jul15-07, 04:28 AM | #7 |
There should not be such a thing as a quick reply in math. Rereading my last remarks urges me to give a correction on "you can solve most cubic equations with a goniometric algorithm". I meant cubic equations with 3 real roots and furthermore, most makes no sense at all as we are talking about the set of cubic equations and that set doesn't have a limited number of elements.
| Jul15-07, 05:02 AM | #8 |
| Jul15-07, 10:53 AM | #9 |
You know this goniometric algorithm for sure!
We reduce any cubic equation (further: CE) with real coefficients to a form [itex]V=x^3+px+q=0[/itex]. Then V=0 also has real coefficients. When the discriminant [itex]D=\frac{q^2}{4}+\frac{p^3}{27}\prec0[/itex] we have the “casus irreducibilis”, in which case V=0 has three real roots. We set [itex]x=r\cos\alpha[/itex] and substitute that x into V=0: [itex]r^3{(\cos\alpha)}^3+pr\cos\alpha+q=0[/itex]. There exists a goniometric equality [itex]\cos3\alpha=4{(\cos\alpha)}^3-3\cos\alpha[/itex]. So, we multiply the terms of the left side of V=0 by 4 and replace [itex]4{(\cos\alpha)}^3[/itex] by [itex]\cos3\alpha+3\cos\alpha[/itex]. It gives [itex]r^3(\cos3\alpha+3\cos\alpha)+4pr\cos\alpha+4q=0[/itex] then [itex]r^3\cos3\alpha+4q+(3r^2+4p)rcos\alpha=0[/itex] We can choose [itex]3r^2+4p=0[/itex] and this makes [itex]r^3\cos3\alpha+4q=0[/itex] We assume that [itex]\beta[/itex] meets the condition [itex]\alpha=\beta frac{2k\pi}{3}[/itex] The roots of [itex]V_1=0[/itex] can be written now as [itex]x_k=r\cos(\beta+ \frac{2k\pi}{3})[/itex] with k=1,2,3. ‘ I owe this solution to Dr P. Wijdenes; it’s dated from the times of the pre-calculator math (not to be confused with the pre-calculus math). No it didn't occur to me that solving a CE is the inverse of cubing. If I have a polynom of the 3rd power with real coefficients and I multiply this polynom with a factor, say, x-2, then I have a quartic equation with three cubic rootsand a root x=2. All I want to say is that it's not at the first sight clear: there are dark corners in the set of real numbers. |
| Jul15-07, 04:18 PM | #10 |
Sorry, again a correction.
False is: we assume that [itex]\beta[/itex] meets the condition etc. Correct is: We have to solve [itex]\alpha[/itex] in[itex]cos3\alpha=frac{-4p}{r^3}[/itex] We assume that [itex]\beta[/itex] is a solution for [itex]\alpha[/itex] in this equation. then [itex]\alpha=\beta+frac{2k\pi}{3}[/itex]. Now the roots [itex]x_k[/itex] of V=0 are equal to [itex]rcos(\beta+frac{2k\pi}{3})[/itex] with k=1,2,3. |
| Jul15-07, 04:23 PM | #11 |
Sorry, again a correction.Now I understand what went wrong!
False is: we assume that [itex]\beta[/itex] meets the condition etc. Correct is: We have to solve [itex]\alpha[/itex] in [itex]cos3\alpha=\frac{-4p}{r^3}[/itex] We assume that [itex]\beta[/itex] is a solution for [itex]\alpha[/itex] in this equation. then [itex]\alpha=\beta+\frac{2k\pi}{3}[/itex]. Now the roots [itex]x_k[/itex] of V=0 are equal to [itex]rcos(\beta+\frac{2k\pi}{3})[/itex] with k=1,2,3. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Cubic roots
| Prove that a cubic has no rational roots | Calculus & Beyond Homework | 6 | ||
| Finding the Roots of Cubic | Precalculus Mathematics Homework | 7 | ||
| Roots of a cubic polynomial | Precalculus Mathematics Homework | 4 | ||
| cubic equation roots | Precalculus Mathematics Homework | 5 | ||
| Cubic with three real irrational roots. | General Math | 5 | ||
