Calculate Tire Pressure After Compression & Heating
  • Thread starter Thread starter trah22
    Pressure
The problem involves calculating tire pressure after air compression and heating in an automobile tire. The original conditions include an air temperature of 10 degrees Celsius and normal atmospheric pressure, with the air compressed to 28% of its original volume and heated to 40 degrees Celsius.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the ideal gas law and the relationship between pressure, volume, and temperature. There are attempts to clarify the correct temperature scale and how to express final volume in terms of initial volume. Some participants express uncertainty regarding their calculations and the implications of volume changes.
Participants are actively engaging with the problem, exploring different approaches to relate pressure, volume, and temperature. Some have provided guidance on using ratios and the ideal gas law, while others are verifying their calculations and questioning their assumptions about volume changes.
There are discussions about the conversion of temperatures to Kelvin and the implications of volume changes due to heating. Participants are also navigating the requirement to express pressure in Pascals and the potential for errors in their calculations.
trah22
automobile tire is inflated with air originally at 10 degrees celsius and at normal atmosphere pressure. During the process the air is compressed to 28% of its original volume and the tempreture is increased to 40 degrees celsius, what's tire pressure?
pv=nrt so p=nrt/v
p=(not sure what to use for n)(.0821)(30K)/(72)
i subracted 28 from 100 to get 72 for volume not sure if that's right(i also posted this question in the advanced physics forum by too i wasnt sure where to put it)
Realize that PV/T = constant: use ratios. If you call the original volume V, what is the final volume? What are the initial and final temperatures? (What temperature scale must you use?)
the temp has to be in kelvin, according to my notes for equation of state, so the intial temp was 283 K and the final is 313 hence my 30K value in my attempted solution... um is pv/t=constant because pv=nrt=Nkt? I know volume and temp are related(if temp increases volume increases) but i don't see exactly how to relate them according to what u said...
trah22 said:
...is pv/t=constant because pv=nrt=Nkt?
Yes.
Try this:
[tex]\frac{P_1 V_1}{T_1} = \frac{P_2 V_2}{T_2}[/tex]
Fill in the values as best you can. Hint: How would you write [itex]V_2[/itex] in terms of [itex]V_1[/itex]?
well, P1(v1)/283K=P2(v1*.28)/313..
arghh jeez as u can tell physics is not my fortay, I am a bio-chem major
Good. Now just solve for P2 in terms of P1 and you're done.
P2=(313(P1)(V1))/((v1(.28)(283))
=313(P1)(v1)/(79.24(V1))
=3.95(p1)
did calculate it out correctly?
there's 1 more part to this question, after the car is driven at a high speed, the tire air temp rose to 85 degrees celsius and the interior volume of the tire increased by 2%, what's the new tire pressure in pascals?
(P2)V2/(313)=((P3(V2(.2)/(358)
P3=358(p2)(v2)/313(v2*.2)
=358p2(v2)/62.6v2
=5.718(P2)
but according to the question i need to put it in pascals...
=3.95(p1)
Looks good. Note that you are given P1--that's atmospheric pressure. So you can express your answer in terms of Pascals.
=358p2(v2)/62.6v2
=5.718(P2)
Where did you get T3 = 358? And if the volume increases by 2%, what is V3 in terms of V2?
You are finding P3 in terms of P2, but you know P2 in terms of P1--and thus Pascals--from the first part of the problem.
alright, 1atm=1.013x10^5 pascals so P2=4.0x10^5 pascals,
for t3 i just took the 85 degrees celsius and converted to 358K
alright here's my go at the problem again in terms of volume and pressure,
4x10^5Pa(v2)/313K=P3(V2(.02)/358
P3=358(4x10^5)(v2)/313(v2(.02)
p3=1.43x10^8/6.26
p3=2.28x10^7Pa
i had to have messed up somewhere that's way to large of a value, did i plug in the worng value for the pressure.. i just used the coversion value for pascals...
OK, good. But V3 does not equal V2(0.02). That's way off. The volume increases by 2%--you have it decreasing by 98%.
oh so it should have been v2(.98)
so P3=4x10^5Pa(358)(v2)/313(v2(.98)
=4.668x10^5Pa
does this large of a value for pressure seem correct but anyhow thanks for all the help,i appreciate it:smile:
No, but you're getting closer. This time you have the volume decreasing by 2%.
interior volume increases by 2%, so the original v2 is 100% plus 2% increase so v2(1.02)... ud just add the 2% since it just increases then..
Now you've got it.
heh thanks for all the help again doc
  • · Replies 116 ·
  • · Replies 60 ·
