Calculating Volume of CO2 Released from a Can
  • Thread starter Thread starter rocomath
    Co2 Volume
The discussion focuses on calculating the volume of CO2 released from a sealed aluminum can containing a flavored solution at 3.00 atm when opened to 1.00 atm at 20°C. The key formula used is Henry's Law, represented as C1/P1 = C2/P2, where C1 is the concentration of CO2 at 3 atm, P1 is the initial pressure, and P2 is the final pressure. The Henry's Law constant for CO2 at 20°C is crucial, and participants emphasized the importance of using correct units for the constant. The Ideal Gas Law was also applied to finalize the calculations.
  • Understanding of Henry's Law and its application in gas solubility
  • Knowledge of the Ideal Gas Law and its components
  • Familiarity with pressure and concentration units
  • Basic grasp of thermodynamics related to gas behavior
  • Research the application of Henry's Law in different solubility scenarios
  • Explore the Ideal Gas Law and its implications in real-world gas calculations
  • Study the effects of temperature on gas solubility and pressure
  • Investigate the significance of unit conversions in scientific calculations
Chemistry students, environmental scientists, and anyone involved in beverage production or gas solubility research will benefit from this discussion.
rocomath
I am so lost as to how I should approach this problem
A soft drink is made by dissolving CO2 @ 3.00 atm in a flavored solution and sealing the solution in an aluminum can @ 20C. What volume of CO2 is released when a 355-ml can is opened to 1.00 atm @ 20C and all the CO2 is allowed to escape?
i have the constant for CO2 @ 20C but from there, I'm confused? S(CO2) = k(CO2 @ 20C) x P(CO2)
Since the temperature remains the same at the two temperatures, and the solvent as well, the Henry law constant remains the same for the unopened can and the opened one. The relationship you are looking for is:
C1/P1 = C2/P2
where C1 is the concentration of CO2 at 3 atm. (20C), P1 is 3 atm and P2 is 1 atm.
Be careful regarding the units of k, the Henry constant. It should be in units of atm/C, where 'C' is in the same units as C1 and C2.
thanks! i was able to do it with a little more thinking.
i had to eventually use the ideal gas law.
  • · Replies 27 ·
