AM vs. FM Quality: Is MHz the Key Difference?
  • Thread starter Thread starter DaveC426913
    Fm Quality
The discussion centers around the differences in audio quality between amplitude modulation (AM) and frequency modulation (FM) radio broadcasting. Participants explore various factors contributing to the perceived superiority of FM over AM, including modulation techniques, frequency ranges, and audio frequency response.
  • Some participants suggest that FM's superiority is due to its frequency modulation being less susceptible to distortion compared to AM's amplitude modulation.
  • Others speculate that the absolute frequency of FM (in the Megahertz range) contributes significantly to its quality, as it may penetrate better and support more subtlety in the signal.
  • A participant notes that AM signals can sound good under certain conditions, such as late-night listening, despite the challenges of signal strength and channel drop-outs associated with FM.
  • One participant discusses the impact of multipath interference on signal quality, explaining that AM's lower frequency allows it to handle multipath variations better than FM would if it were using AM techniques.
  • Another participant highlights the difference in audio frequency response, stating that AM stations have a limited bandwidth which affects high-frequency reproduction, while FM has a broader bandwidth allowing for better fidelity of high-frequency sounds.
  • Further details are provided about the regulatory bandwidth allocations for AM and FM stations, including dynamic range differences and the historical context of AM stereo broadcasts.
Participants express various viewpoints on the reasons behind FM's superior quality, indicating that multiple competing views remain. There is no consensus on whether the modulation technique or the frequency range is the primary factor influencing audio quality.
Participants mention limitations in AM radio quality due to factors like bandwidth restrictions and receiver technology, which may affect the overall listening experience. The discussion also touches on historical practices and regulatory changes that have influenced AM and FM broadcasting.
DaveC426913
2025 Award
Correct me if I'm wrong.
I've always taken it on faith that the switch to frequency modulation from amplitude modulation resulted in the much better quality signal and listening experience we have today. Modulation of the frequency is likely less susceptible to distortion than is modulation of the amplitude, meaning that, all other things being equal, FM will prodice a more faithful signal with less degradation.
But ...
I speculate that modulation is not the largest component of why FM is so much better quality radio. Surely a much larger component is the absolute frequency i.e. FM is in the Megahertz range whereas AM is merely the kilohertz range. MHz will penetrate better, support more more subtlety in the signal, have better redundancy (thousands of carrier cycles per signal cycle as opposed to dozens) and a host of other improved properties.
So: It seems to me that AM radio in the Megahertz range would be much more nearly comparable to FM radio.
True?
Computer science news on Phys.org
But ...
True?
Interesting notion. Certainly, the late-night AM signals from Albany and Buffalo sounded great when I was about 12 or so (1964) and listened to my little radio at night. The switch to FM was fraught with signal-strength problems ans channel drop-outs.
Good question Dave. (and thanks again for your help in that vision physiology thread -- much appreciated)
The best way to think about AM versus FM (for analog RF audio transmissions), is to think about the main impairments that the radio channel has to deal with. There are certainly noise impairments that affect both AM and FM, but the main impairment for moving radio receivers (like car radios) is multipath. The signal that you receive is the sum of the main signal (if you have a reasonable line-of-sight to the transmitting antenna) plus all of the reflected signals off buildings, metal towers, people, etc. The reflection amplitudes depend on the frequency of the radio channel obviously, but you will almost always be dealing with a composition of the multipath signals in your receive antenna and receive amp.
So, multipath affects the amplitude of the received signal, and if you are driving around and the multipath composition is varying at audio frequencies, then your radio will sound awful. Luckily, the AM band is low enough in frequency (around 1MHz) that the variation due to multipath is at a low enough frequency that it doesn't bleed past the audio bandpass filters very much. But up in the broadcast FM band frequencies, if they tried to use analog AM, the multipath amplitude variations with time would destroy the audio.
And no matter where you are in the spectrum, you will generally try to only use a bandwidth that is wide enough to transmit the data (analog or digital) that you want to transmit. Of course, the regulatory agencies know how wide each designated use band should be anyway, so that's what you get.
Make sense?
For me, one of the biggest differences between the AM and FM broadcast bands is audio frequency response. If I remember correctly, AM stations are allocated 10 KHz of bandwidth, which means that audio frequency response has to be down substantially at 5 kHz. The high-frequency audio response for FM signals is much better, so sound from musical instruments that have high (audio) harmonic content (eg., cymbals) are reproduced more faithfully by FM signals.
That's 10khz between stations. In the USA adjacent stations aren't allowed, and some AM stations used 20khz of bandwidth. Dynamic range was about 50db (rate of change of volume impacts bandwidth). Later the FCC started enforcing the 10khz rule. Also because of the wave bouncing off the air layers at night, AM stations had to cut power, except for the few that had "clear" channels (no other station on that channel in the USA). This allowed stations like KOMA (Oklahoma) to be heard from just east of the Rockies to the Applachian Mountains) at night time. XERB, broadcast from Mexico, covered most of the south western states (Wolfman Jack was on XERB). There was a short period of time when AM stereo stations existed, apparently using "two channels" to get 15khz on both channels.
FM stations are separated by 100khz, and again in the USA, adjacent stations aren't allowed. However each 100khz is broken up into smaller bands. 15khz for mono (left + right), 15khz for each stereo channel, and then some other stuff like the digital stuff (like song names you can see on a radio). FM dynamic range is around 70db; this is a factor of the maximum frequency deviation from the "center" frequency (which represents 0 db). Having both mono and stereo signals, if the signals get weak, FM receivers can combine the signals, transitioning into full mono mode to compensate.
Note also that modern receivers generally have terrible AM radios (reducing response to around 5khz, when 10khz is available), as there's no demand for maximizing the AM quality.
Widipedia has a descent article on all this stuff.
