Normal modes, 2 masses, 2 springs
This discussion focuses on calculating the normal mode frequencies for a system consisting of two masses and two springs, characterized by spring constants k1 and k2. The equations of motion are derived as m&ddot;x = -k2x + k1(y-x) and m&ddot;y = -k1(y-x). The determinant condition leads to the frequency solutions α1,2 = 1/2[ (k2/m + 2k1/m) ± sqrt[(k2/m + 2k1/m)² - 4(k2k1/m²) ]]. The user seeks assistance with amplitude ratios and inquires about simpler equation-writing tools.
  • Understanding of normal modes in mechanical systems
  • Familiarity with differential equations in physics
  • Knowledge of spring constants and mass-spring systems
  • Basic algebraic manipulation and determinant calculations
  • Study the derivation of normal modes in coupled oscillators
  • Learn about the implications of spring constants in oscillatory motion
  • Explore software tools for visualizing mechanical systems, such as MATLAB or Python with SciPy
  • Research methods for solving differential equations related to mechanical vibrations
Students studying classical mechanics, particularly those focusing on oscillatory systems, as well as educators and tutors assisting with physics homework related to normal modes and coupled oscillators.
Hume Howe
hey, this is my first time using this forum and was wondering if i could have some help with this normal modes question.
suspended from a ceiling is in order: a spring of spring constant ([tex]k_{2}[/tex]), a mass (m), a spring with spring constant ([tex]k_{1}[/tex]), and another mass (m)
calulate the normal mode frequencies [tex]\alpha_{1}[/tex], [tex]\alpha_{1}[/tex] sorry can't find the omega symbol.
attempted solution:
let the displacement of the higher mass be x and the displacement of the lower mass be y.
m[tex]\ddot{x}[/tex]=-[tex]k_{2}[/tex]x + [tex]k_{1}[/tex](y-x)
m[tex]\ddot{y}[/tex]=-[tex]k_{1}[/tex](y-x)
[tex]\left| \alpha^{2} - (\frac{k_{2}}{m} + \frac{k_{1}}{m}) -----\frac{k_{1}}{m} \right|[/tex]
[tex]\left| \frac{k_{1}}{m} -------- \alpha^{2} - \frac{k_{1}}{m} \right|[/tex] = 0
determinant = 0
so [tex]\alpha^{2}[/tex] = 1/2[ ([tex]\frac{k_{2}}{m}[/tex]+ [tex]\frac{2k_{1}}{m}[/tex]) +- sqrt[([tex]\frac{k_{2}}{m}[/tex]+ [tex]\frac{2k_{1}}{m}[/tex])^2 – 4([tex]\frac{k_{2}*k_{1}}{m^2}[/tex])]]
after simplifying it doesn't work when I use to try and solve for the amplitude ratios.
please advise, thanks.
p.s. is there a simpler equation writer i could download and use here or should i just persevere and try to use this embedded one?
Homework Equations m*\ddot{x} = -k_{2}*x + k_{1}(y-x)m*\ddot{y} = -k_{1}(y-x)The Attempt at a Solution let the displacement of the higher mass be x and the displacement of the lower mass be y.m\ddot{x}=-k_{2}x + k_{1}(y-x)m\ddot{y}=-k_{1}(y-x)\left| \alpha^{2} - (\frac{k_{2}}{m} + \frac{k_{1}}{m}) -----\frac{k_{1}}{m} \right|\left| \frac{k_{1}}{m} -------- \alpha^{2} - \frac{k_{1}}{m} \right| = 0determinant = 0so \alpha^{2} = 1/2[ (\frac{k_{2}}{m}+ \frac{2k_{1}}{m}) +- sqrt[(\frac{k_{2}}{m}+ \frac{2k_{1}}{m})^2 – 4(\frac{k_{2}*k_{1}}{m^2})]]\alpha_{1,2} = 1/2[ (\frac{k_{2}}{m}+ \frac{2k_{1}}{m}) +- sqrt[(\frac{k_{2}}{m}+ \frac{2k_{1}}{m})^2 – 4(\frac{k_{2}*k_{1}}{m^2})]]^{\frac{1}{2}}
  • · Replies 20 ·
