Thread Closed
How do you find the frictional force acting on an object if it is decelerating?
Share Thread Thread Tools
Jul22-07, 03:04 AM   #1
Q : A train of mass 8.0 [tex]\times[/tex] 10[tex]^{}6[/tex] kg, travelling at a speed of 30 m s[tex]^{}-1[/tex], brakes and comes to rest with a constant deceleration in 25s.
(a) Calculate the frictional force acting on the train while decelerating.
(b) Calculate the stopping distance of the train.
2. Relevant equations
I have no idea which equations to use...
3. The attempt at a solution
Well... first i found the net force which is zero because it is contant negative acceleration. I then attempted a diagram. I dont know what do do next.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jul22-07, 03:30 AM   #2
Quote by lina45 View Post
Are you sure? Would Newton's second law agree with that statement?
Jul22-07, 03:43 AM   #3
Recognitions:
Homework Helper Homework Help
In the first question, you are asked for a force. I know an equation that gives you the net force, namely: F = m a. But, there is an unknown in it, the acceleration. Since you know the initial velocity and stopping time, can you calculate the acceleration from this? And once you have the net force, is this also the force requested or might this be a sum of the force you actually want and some other force(s)?
In b, you need an equation that will give you the distance. Try [tex]s = \tfrac12 a t^2[/tex] - which unknowns are there and how can you determine them?
Jul22-07, 03:58 AM   #4
but wouldnt the net force be zero because when you use the formula F = ma isnt constant deceleration regarded as zero acceleration?
Jul22-07, 04:25 AM   #5
Careful. Constant velocity is zero acceleration.
Jul22-07, 04:49 AM   #6
howcome the formula s = [tex]\frac{}{}1/2[/tex] at[tex]^{}2[/tex] used instead of s = ut + [tex]\frac{}{}1/2[/tex] at[tex]^{}2[/tex]
Jul22-07, 05:14 AM   #7
Using s to denote displacement and u to denote velocity, the full kinematics equation for displacement is [tex]s = s_0 + u_0 t + \frac{1}{2} at^2[/tex], where [itex]s_0[/itex] is initial displacement and [itex]u_0[/itex] is initial velocity. If both of these are zero, they just drop out. So that just leaves us with [tex]s = \frac{1}{2} at^2[/tex]. Hope this helps.
Thread Closed
Thread Tools
Similar Threads for: How do you find the frictional force acting on an object if it is decelerating?
Thread Forum Replies
Find frictional torque acting on the pulley? Introductory Physics Homework 18
Frictional forces acting on log Application of Newtons Laws Introductory Physics Homework 3
Friction or some force acting on momentum of an object Introductory Physics Homework 4
Force acting on rotatble object Classical Physics 2
Another Question: Find the work done by the kinetic frictional force Introductory Physics Homework 1
