NEVER connect an ammeter in parallel ->WHY?
  • Thread starter Thread starter hiyoo89physics
    Ammeter Parallel
The discussion revolves around the proper connection of an ammeter in electrical circuits, specifically addressing why it should not be connected in parallel with a power source. Participants are exploring the implications of such a connection and its effects on circuit behavior.
  • Participants are attempting to understand the consequences of connecting an ammeter in parallel, questioning the relationship between resistance, current, and the potential for blowing a fuse. There are discussions about the differences in current measurement when connected in series versus parallel.
The discussion is ongoing, with participants sharing their understanding of the concepts involved. Some have provided insights into the relationship between resistance and current, while others are seeking clarification on why a fuse would blow in this scenario. There is a general exploration of the principles behind ammeter and voltmeter functionality.
Participants are working with the assumption that an ammeter has low resistance and that connecting it in parallel creates a short circuit, leading to high current flow. There is a lack of consensus on the detailed mechanics of why this results in a blown fuse.
hiyoo89physics
"NEVER connect an ammeter in parallel!" -->WHY?!
Why must an ammeter never be connected in parallel, or across the terminals of a power source?
All I know about this is that you'll blow a fuse if you connect an ammeter in parallel... but I don't know why you'd blow a fuse.
My guess: The current that you'd measure if the ammeter was connected in series would be the current that had gone through the resistor, so the current would be lower than the current coming straight out of the power supply. This un-resisted (?) current is too high for the ammeter to bear.
If you could help me on this, I'd be so grateful! THANK YOU!
If you hook up an ammeter in series, it measures the entire current through the circuit. If you hook it up parallel to it, it will not experience the entire current through the circuit but only a fraction of it.
The more stuff you put in series, the higher the combined resistance will get.
Because an ammeter has low 'resitance/impedance'. It is designed to measure the current. A high impedance would reduce the current and add a voltage drop.
Placing an ammeter in parallel produces a 'short circuit' and the resulting current will 'blow a fuse'.
Conversely, a voltmeter has a high impedance and is placed in parallel.
when does a fuse blow up??
because of the heavy current.
when you put an ammeter in parrallel, you are reducing the resistance of the circuit(ammeter has very low resistance).
low resistance = high current = blown fuse
  • · Replies 31 ·
13K
  • · Replies 59 ·
14K
