Solve Vehicle Physics Problem: Find Maximum Ground Speed with Headwind
  • Thread starter Thread starter hallo
    Physics Vehicle
The discussion focuses on calculating the maximum ground speed of a vehicle on a mountain at 4400ft elevation, powered by a 400hp engine with a drag coefficient of 0.5 and a frontal area of 20ft². The user successfully computed the maximum speed in still air but encountered difficulties when factoring in a 20mph headwind. The key formula used is Power = drag coefficient * 1/2 * Area * density * velocity³, which requires differentiation to find V(max) under headwind conditions.
  • Understanding of vehicle dynamics and physics principles
  • Familiarity with drag coefficient and its impact on speed
  • Knowledge of power-to-speed relationships in automotive engineering
  • Basic calculus for differentiation and optimization
  • Study the principles of aerodynamic drag and its calculation
  • Learn about the effects of headwinds on vehicle performance
  • Explore optimization techniques in calculus for maximum/minimum problems
  • Research vehicle powertrain efficiency and its relation to speed
Automotive engineers, physics students, and anyone interested in vehicle performance optimization will benefit from this discussion.
hallo
Hi,
A vehicle land on a mountain of 4400ft.The Engine delivers 400hp to the wheels and careful streamlining has resulted in a drag coefficient of 0.5,based on a 20ft^2 frontal area.Compute the maximum ground speed of the car in i)still air and ii)with a 20mph head wind
for part i)I have solve using coefficient power and drag coefficient formulas.However the part ii), I am haveing problem.
Pls help.
thanx
If one solve part i, then part ii should be solvable.
With a head wind, the maximum vehicle velocity is reduced.
How does one solve for Vmax?
If one sets up an equation in V, then with a headwind try V+Vhead, where Vhead is the headwind velocity.
I have solve till Velocity but not V(max). my eqn is
Power= drag coeff * 1/2 * Area * density* velocity^3
to find V(max),what should I set to zero and then differentiate?? ??
  • · Replies 169 ·
17K
  • · Replies 18 ·
  • · Replies 271 ·
49K
  • · Replies 124 ·
21K
