Prove Hyperbolic Cosine Sum-to-Product Identity
  • Thread starter Thread starter bakin
    Cosine Hyperbolic
The discussion revolves around proving the hyperbolic cosine sum-to-product identity: Cosh(x) + Cosh(y) = 2Cosh[(x+y)/2]Cosh[(x-y)/2]. The subject area includes hyperbolic functions and their relationships to trigonometric functions.
  • Participants explore the possibility of applying the cosine sum-to-product formula to hyperbolic cosine. Questions arise regarding the relationship between cosine and hyperbolic cosine, as well as the implications of using their exponential definitions.
Some participants have provided insights into the relationships between hyperbolic and trigonometric functions, suggesting methods for proving the identity. There is an ongoing exploration of different approaches, with no explicit consensus reached yet.
Participants note a lack of familiarity with the connections between cosine and hyperbolic cosine, indicating that the topic was covered briefly in their studies. There is also mention of using definitions and properties from Euler's Identity to aid in the proof.
bakin
Prove the identity:
Cosine sum-to-product
http://library.thinkquest.org/17119/media/3_507.gif
Can you use the same formula for Cosine sum to product for hyperbolic cosine?
Thanks!
Do you know how cos x is related to cosh x?
Or more precisely, how x and y are related if cos x=cosh y?
To prove your identity, you could use a variant of the proof you hopefully used for cos.
I'm not sure how they're related, we went through them very quickly and very briefly. I do know that cosh(x) is e^x + e^-x all over 2, but we didn't spend a lot of time on them.
The relation is pretty simple, cosh(x)=cos(i*x). It's pretty easy to show this using the power series for cos(x) and e^x. Does that help?
Or Alternatively, from Euler's Identity a definition of cosine follows:
[tex]\cos x = \frac{ e^{ix} - e^{-ix}}{2}[/tex]. That explains the connection.
As for another method to prove the relation, replace all the Hyperbolic Cosines with their exponential definition and rearrange into what you want to see.
That works! I replaced the right side into the definition, combined terms, and then separated, and got it. thanks a lot guys.
  • · Replies 16 ·
