How Does a Car Amplifier Boost Speaker Power?
  • Thread starter Thread starter Vvega511
    Amp
The discussion centers around how car amplifiers boost power to speakers, particularly in the context of car audio systems. Participants explore the mechanisms of amplification, the relationship between voltage and power, and the capabilities of car electrical systems to support high power outputs.
  • One participant questions how a 1000-watt amplifier operates and how a car's electrical system can handle high power outputs.
  • Another participant explains that a watt measures energy flow and relates it to the energy capacity of a car battery and the role of the alternator in recharging it.
  • It is noted that amplifiers take a small input signal and produce a larger output signal by consuming power from the car's alternator.
  • One participant describes the amplifier as a relay that uses a low-power signal to control a high-power source for the speakers, mentioning the use of auxiliary batteries and alternators in high-decibel systems.
  • A question is raised about whether an amplifier increases voltage to the speakers.
  • A response clarifies that amplifiers do not increase voltage in the manner of a transformer but rather modulate a high-power source to follow the original signal pattern, emphasizing that the available amperage is what gets boosted.
  • Another participant reiterates that amplifiers output a larger signal, which can make sounds louder by allowing a larger voltage to be applied to the speakers.
Participants express differing views on the specifics of how amplifiers function, particularly regarding the relationship between voltage and power. There is no consensus on the exact mechanisms or terminology used to describe amplification in car audio systems.
Some participants reference the complexity of amplifiers and their components, such as transistors, without delving into detailed explanations. The discussion also touches on the energy dynamics of car batteries and alternators, which may not be fully resolved.
Individuals interested in car audio systems, electrical engineering, or the principles of amplification in audio technology may find this discussion relevant.
Vvega511
I know that in car audio systems amps are used to increase power to the speakers especially the subwoofers but how exactly does it do that? If an amp is 1000 watts and watts is volts times amps than what is the amp doing to make the 1000 watts? Also in some cars that have systems that are sometimes 4000 watts or more how is the cars electrical system able to handle that kind of power? Any enlightenment will be much appreciated. Thank you.
Think in terms of energy. A watt is a measure of energy flow per unit time. Unit of energy is a joule (J), so a watt is a joule per second J/s. (watt is also Volt Amp same thing)
To give you an idea, a fully charged car battery can hold up to 6 million joules of energy. If you want to dump it at a rate of 1000 J/s (1000 watts) into an amp, it will take 6000 seconds or 2 1/2 hours to fully expend its energy.
A car's battery is recharged of course, by an alternator. The energy to recharge the battery comes from gas. To give you an idea 1 gallon of gas has about 130 million joules of energy. Most of that energy is converted into motion of the car, and some is used for everything else, including running the alternating.
An amp is composed of transistors that actually do the amplifying. It is a very broad subject to explain all in a single thread. But you can read up about them here,
http://en.wikipedia.org/wiki/Transistor
An amplifier takes in a signal with a small amplitude (a couple of volts from your head unit) and outputs a similar signal with a much, much larger amplitude (even as high as a hundred volts for large speakers). It creates this large version of the signal by consuming power that ultimately comes from the car's alternator.
- Warren
In the simplest terms, you can think of an amp as a relay. The low side of it reacts to a low-power signal and uses it to control a high-power source that goes to the load (speakers). Most vehicles pumping high decibels have auxilliary batteries that are specifically dedicated to running the sound systems. The most powerful ones have auxilliary alternators as well, also driven by the engine.
So an amp works by increasing voltage to the speakers?
No. It doesn't actually increase the voltage in the way that a transformer does; rather, it modulates a high-power source to follow the pattern of the original signal. Any automotive sound system that I've seen still uses 12 volts (or 24 in some special cases); it's the available amperage that gets boosted.
An amplifier takes a small signal, and outputs a similar, yet much larger signal. In that sense, yes, the amplifier ultimately makes sounds lounder by enabling you to apply a larger voltage to your speakers.
- Warren
  • · Replies 23 ·
85K
  • · Replies 16 ·
