Reflecting particles as a solution to global warming?
In summary, this was on PBS's NOVA a few months back. A by-product of greenhouse gas emissions is what I am going to term "macro particles." Thanks to their size and composition, these particles have been reflecting sunlight and therefore reducing global warming, although on balance they could not reverse it. In the absence of these particles, the greenhouse effect would have been more severe. A scientist on NOVA claimed that these particles have reduced the warming effect by about 20%. Are there studies of how this information can be used to further reduce or even reverse GW? Reverse global warming? What global warming? 150 year old news!
EnumaElish
2,350
124
This was on PBS's NOVA a few months back.
http://www.giss.nasa.gov/edu/gwdebate/00fig1.gif
Reverse how many degrees?
Mk
The image link returns a "+".
Did you mean to seriously respond to my post? Or are you just bored?
The figure comes up for me, it's part of this article:
I fail to see Mk's point, what global warming? How about the positive upward trend clearly seen as a red line on the graph?
EnumaElish, I believe this story is quite old news, these particles increase the albedo of clouds, less sunlight reaches the surface (a phenomenon that has been termed "global dimming"). Some say that the effect of these particles has masked the increased strength of the atmospheric greenhouse effect, and that as a result recent temperatures have been cooler than they might otherwise have been. However, new technologies have been developed which have dramatically decreased the need to release these particles, as a result their concentration in the atmosphere will diminish. Potentially this will enable the effect of the greenhouse gases to be more dominant in global warming... although one must bear in mind, there are many more layers of complexity which we are yet to unfold, we are in no position to tamper with Earth's climate in a manipulative, intelligent way, the results of releasing more "cooling" particles could be disastrous for unseen reasons.
It's 150 year old news!
The eruption of Krakatoa put enough sunlight reflecting material into the atmosphere to basically prevent summer happening for most of the world, leading to widespread frost, famine etc.
Recently there was a measurable rise in temperatures across the US for a couple of days after 9/11 when flights were grounded and so not generating highly reflecting contrails.
Actually I see a tiny plus as well now. I'm sorry about that. I meant that in a our chaotic system, what is about two degrees?
Here's a scary one
A method is disclosed for reducing atmospheric warming due to the greenhouse effect resulting from a greenhouse gases layer. The method comprises the step of seeding the greenhouse gas layer with a quantity of tiny particles of materials characterized by wavelength-dependent emissivity or reflectivity, in that said materials have high emissivities in the visible and far infrared wavelength regions and low emissivity in the near infrared wavelength region. Such materials can include the class of materials known as Welsbach materials. The oxides of metal, e.g., aluminum oxide, are also suitable for the purpose. The greenhouse gases layer typically extends between about seven and thirteen kilometers above the Earth's surface. The seeding of the stratosphere occurs within this layer. The particles suspended in the stratosphere as a result of the seeding provide a mechanism for converting the blackbody radiation emitted by the Earth at near infrared wavelengths into radiation in the visible and far infrared wavelength so that this heat energy may be reradiated out into space, thereby reducing the global warming due to the greenhouse effect.
The details are clearly outlined in U.S.
Patent #5,003,186 at the following link.
http://patft.uspto.gov/netacgi/nph-...5,003,186.PN.&OS=PN/5,003,186&RS=PN/5,003,186
No way would I support such drastic actions unless we had extremely high confidence that it was necessary.
Plan to dump iron in the ocean to offset atmospheric carbon dioxide.
http://news.nationalgeographic.com/news/2007/07/070725-iron-ocean.html
I wish the politicians would go back to the whole "we need to save the trees" spiel from the 80's and lose the "we need to stop global warming" spiel of the present. I mean it was a much less frightening thought to have someone put some unshaved woman up in a tree than it is to have someone actually considering intentionally polluting the atmosphere with potentially harmful chemicals in the hopes of lowering the temperature by a fraction of a degree.
That is a very naive interpretation of the environmental movement. The GW issue is driven by science. Of course the guys down at the local bar would probably disagree; in between belches. :biggrin:
But it's quite a good interpretation of most goverment's conception.
We screwed up the atmosphere by large scale industrial processes where we didn't understand/care about the long term effects, therefore the solution must be a large scale industrial process where ... etc
Similiar science driven arguments were given in the 80's for all the save the whales, trees, etc. movements. For example, people back then were focusing on rates of deforestation, or darwinian genetics, etc. as scientific basis for the save the "insert species here" movements citing similar day of doom scenarios as those for the global warming movement of the present.
The real reason behind all these movements may very well be to give government an excuse to exert controls on industry (the science merely the vehicle used to justify that end), but I suppose I just liked it more when these psuedo science political movements actually had small positive solutions that people were doing (like actually planting trees and saving pointlessly rare animals in rainforests or whatnot). What positive results are coming out of the global warming movement? People buying more Toyota's?
In europe energy saving CFD light bulbs are becoming the standard, people are seeing recycling as a duty and I think fashions have turned against SUVs.
Of course this is more than offset by the increased amount of flying people do !
And don't get me wrong, the technology that the hybrids use (harvesting the extra heat generated during combustion to charge a battery) is an excellent idea to be sure and an improvement environmentally. Though I am not sure the global warmers can take credit for the recycling movement, that was an 80's success all the way.
I am actually quite enthusiastic about the idea of politicians breathing less often as a solution to global warming...this would certainly lead to decreased overall CO2 levels. The challenge with getting this through I suppose would be to convince a politician that they actually breathe out CO2 to begin with (it's already hard enough to convince them that they are contradicting themselves when they buy 10 SUV's).
I am guessing that the degree of inclination to agree with GW issues is positively correlated with one's gradient to the nearest open body of water.
Not necessarily. I live near a body of water and I am sort of in the middle on the global warming issue. I am much more for the older save the trees type movements because at least I could see that the "direct" goal that people were told to work for in those was to protect life.
I've listened to the arguments for GW, and while I agree that it is happening, the arguments that I have heard about the "real" dangers of global warming are poor at best. For example, I am told that in 100 years some beachfront property will be lost due to the rising sea level. Trouble is, as anybody living near these things knows, long before that can even happen people in beachfront properties will have to rebuild their properties several times over in that same time period. Why? One reason is that the rate of coastal erosion due to the attack from ocean waves on the beachfront is a MUCH faster and more dynamic process than sea level rise (you can see dramatic changes to most beachfronts just looking at pictures that are ten years apart). Living on the beach to begin with is impractical (expensive) at present mainly for this reason and NOT GW. That's why only rich people who afford the hefty insurance do it (well, and bums who live without a real home on the beach...but there is no danger to their "property").
FAQ: Reflecting particles as a solution to global warming?
1. What are reflecting particles and how can they help with global warming?
Reflecting particles, also known as aerosols, are tiny particles suspended in the atmosphere that can reflect sunlight back into space. This can help cool the Earth's surface and counteract the warming effect of greenhouse gases.
2. How do reflecting particles compare to other proposed solutions for global warming?
Reflecting particles are one of many proposed solutions for global warming. Some other solutions include carbon capture and storage, renewable energy sources, and geoengineering. Reflecting particles are often seen as a temporary solution and not a long-term fix, as they do not address the root cause of global warming.
3. What are the potential risks associated with using reflecting particles?
Some potential risks associated with using reflecting particles include unintended consequences such as changes in precipitation patterns and damage to the ozone layer. There is also the risk of delaying the necessary actions to reduce greenhouse gas emissions, as reflecting particles only provide temporary relief from global warming.
4. How feasible is it to implement reflecting particles as a solution to global warming?
The feasibility of implementing reflecting particles as a solution to global warming depends on various factors such as cost, technological capabilities, and potential side effects. Some experts argue that it may be more feasible to focus on reducing greenhouse gas emissions rather than relying on temporary and potentially risky solutions like reflecting particles.
5. Are there any ongoing research or initiatives related to reflecting particles as a solution to global warming?
Yes, there is ongoing research on the use of reflecting particles as a potential solution for global warming. Some initiatives include the Stratospheric Controlled Perturbation Experiment (SCoPEx) and the Marine Cloud Brightening Project (MCBP). However, there is still much debate and ethical considerations surrounding the use of reflecting particles, and more research is needed before they can be considered a viable solution.
45K
23K
20K
