What affects the force of friction in an investigation?
  • Thread starter Thread starter grade11
    Motion Surface
The discussion revolves around understanding the forces acting on a cake box being held by Cathy as she takes the bus, specifically focusing on tension, friction, and acceleration. The participants explore how to calculate the force exerted on the string, the coefficient of static friction, and the effects of acceleration on the box's movement.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Newton's laws to determine forces, questioning how to account for upward and downward forces. There are attempts to clarify the relationship between normal force and frictional force, with some participants expressing confusion about how to derive necessary values from given information.
Some participants have provided guidance on using free body diagrams and the equations of motion, while others are still seeking clarity on specific calculations and concepts. Multiple interpretations of the problem setup are being explored, particularly regarding the role of the string and the forces involved.
Participants mention a lack of background in physics and the absence of a teacher, which contributes to their frustration and confusion. There is a focus on understanding how various factors, such as weight and surface area, affect friction, with suggestions for conducting an investigation to measure these effects.
grade11
Ok i tried these questions over and over and i cannot seem to grasp the idea so if someone could please just give me the full answer to this it would be greatly appreciated so i can see fully how to do it and i can apply it to similar questions...
1. a) Cathy takes the bus home from work. In her hand she holds a 2.0 kg cake box, tied together with string. As she ascents the steps into the bus, the box accelrates upward at a rate of 2.5 m/s^2. What is the force exerted on the string? (ok is this a tention question or how do i do this, can anyone prove an explanation or a full answer? )
b) Cathy sets the box on the seat beside her. the bus accelrates from rest to 60 kn/h in 4.0s, and the box begins to slide. What is the coeffiecent of static friction between the box and the seat of the bus? (ok i know that Ff=Us(Fn) I know Fn = ma i know a=v2^2-v1^2/2d i found d by doing .5(v1 + v2)(t) so i can find accelration i find Fn = m which is 2 kg and acelartion which i believe is 4.1675 m/s^2 but i am left with a equation iwht 2 variables Ff=Us(Fn), Therfore Us = Ff/Fn i know Fn but i do not know Ff, please someone enlighten me)
c)A taxi suddnelt cuts in front of the bus, causing the bus driver to slam on the brakes. The bus driver reduces speed from 60km/h to 20km/h in 1.5s. Does Cathy's cake slide forward? (is this Uk? i need major help with this one, this is accelration isn't it?)
Ok Next question...I have to design and complete an investigation to determine how the folloing factors affect the force of friction:
wieght
Surface area
speed
I need to measure the magnitude of the force of friction. any suggestions on how i should go about this?
Please help me PLEASE i am taking sorrespondant physics during my summer break and it is really hard i have no teacher and no background in physics, PLEASE help.
Do you know f = m a ?
F = m a again, you are then supposed to assume that this is just enough to overcome friction. You know that friction foce = weight * coefficient.
f = m a again! This time you also know the fricional force trying to stop it accelearating forward
You can measure the frictional force by simply measuring the force needed to start the object slipping ( using a spring balance?).
Then from knowing force = weight * friction coef.
Do study the other values rememebr that you want to vary only one parameter at once.
i do know f = ma but the question can't be that simple A) plus it is being exerted upward so wouldn't it have to be Fn= ma - (-fg)?? thus Fg = 2(9.8) = 19.6N Fn= 2.0 (2.5)-(-19.6) = 24.6 N?this right ??
b)please help more also with c please help more
It is almost that simple, you have f = m a downward, where a=g and at the same time f = m a upward where a=2.5. Assuming you typed the figures into your calculator correctly! They obviously add because jerking it upward increases the force on the string, it's always worth trying to understand which direction the forces act rather than just hoping to get all the signs correct.
b, For the bus accelerating, first convert everything into m/s
Then you know the start speed =0, you know the end speed and you know time so 'a' shouldn't be too difficult - check out the equatons of motion in the physics formulae thread https://www.physicsforums.com/showthread.php?t=110015
You know the normal force down on the seat ( the weight), you can calculate the forward force ( f=ma) , and so the friction coef is easy.
ya but i need to get the static friction Ff=UsFn that's cool that i have Fn now but how doi get another variable ?
i need a lot of help with this this is getting me soo frusterated because i do not have another number i only know the Fn that's it FF=UsxFn i need another thing then just Fn how do i find Ff or Us?
:confused: I think that it is pedagogically more sound to always tell students that there is only one acceleration vector at any time for any object. It is my experience that talking about more than one acceleration is simply misleading and confusing. The equation simply says that the net force is equal to m times the (unique) acceleration.
I will help you. Just give me a minute to read your posts, ok? Stay around.
I will start with this one since it's not totally clear to me what the situation is.
To do those problems, it is always very very useful to start with a free body diagram. Believe me, once you have the FBD, more than 3/4 of the work is done.
But I am not sure I can picture the situation here. Do they mean that she is holding a string which is attached to the box? In that case, what are the forces and their directions acting on the box?
serously i don't know i honestly do not know i take correspondants physics and they give me these books i have no teacher and no help except this site. that's the question i don't think she is holding the string but its very possible she's holding the string but logically who holds a cake with a string attachted to it like its your dog?? so I am going to say that the string is just holding the package togeather? wat do u think?? that's a very valid point tho what is the question asking?
i seroisuly believe that the string is just holding the box togeather because it says she is holding the cake which is help togeather by string so i know that a force in the upward motion is Fn=ma-(-fg) because it is moving up ward thus fg = 2 (9.8) =19.6N then ma = 2(2.5) thus Fn =2(2.5)-(-19.6) = 24.6 N
Now B part is a little different i have v1=0.0m/s v2=60km x 1000 / 3600 = 16.67m/s i have t=4s and i need to find Ff=Us(Fn) ?? or is there another eq
as for a free body diagram...this is wat i believe it looks like please correct this if i am wrong before in question a it was going vertical but now if its on a seat then it will be horisontal Fapplied<----o->Ff ? hte Fapplied is the force applied by the accelration correct?
Ok - looks like you have tried !
a, There is a force downward of = 2kg * 9.8m/s^2
And a 'jerk' upward of 2kg * 4m/s^2
So total F = 2*9.8 + 2*4 = 24.6N
As I said, rather than just trusting getting the signs correct think about the forces, the weight pulls down and the acceleration upward both are trying to break the string so the overall force must be larger, ie add them
b, The bus accelarates from 0 - 60Km/h in 4s that is 4m/s^2 (assuming I did the sums correct!). By F=ma that exerts a sideways force on the 2Kg box of 8N.
The co-efficent of friction is defined so that the sideways force = the downward force * friction.
We know the downward force is F=2g ie 2*9.8 = 19.6N
The sideways force we just calculated as 8N so the friction.
F (pull) = F (normal) * friction, friction = Fpull/Fnormal = 8/19.6 = 0.41
c, The bus (de)accelarates from 60Km to 20Kmh, ie 40Km/h in 1.5s =7.33m/s^2
The force needed to overcome sideways friction we just calculated as 8N
The force due to (de)accelaration is F = m a = 2kg * 7.33 = 14.67N
This is larger than the friction (8N) so it slides!
ps - please check my actual numbers I was doing the sums in my head ;-)
how did u get the accelration to be 4? did u sue the forumula v2=v1+2a(t) thus v2-v1/2t 16.67m/s-0.0m/s / 2(4) thus equalling 2.01 m/s^2? or how did u do it?
a=2.08m/s^2 Ff=2.0(2.08) =4.16N Fn=2(9.8) = 19.6N
{Ff=Fn(Us)} 4.16N=19.6(Us) Us=4.16/19.6 = 0.21 ?
CORRECT?
and for c if he de accelrates his accelration will be a negative also what formula did u use to find ur a?
60km/h = 60000m/3600s = 16.67m/s in 4s that's 16m/s / 4s = 4.16m/s^2
( I rounded slightly to do it in my head )
The magnitude of the acceleration of the cake is +ve. As I said in the other thread, think about the directions rather than worry about the signs.
  • · Replies 34 ·
