Calculating Shear Stress for Thread in Hydraulic Press
The discussion focuses on calculating the shear stress of a thread in a hydraulic press that exerts a force of 100 tons and pulls at 30 tons. Participants reference the formula A = K*Pi*D*T, where D is the thread minor diameter, Pi is approximately 3.14, T is the thread engagement, and K is a coefficient dependent on internal thread contact. The conversation emphasizes the importance of avoiding shear loading on threads due to stress concentration and recommends using shouldered bolts for safety in high-force applications.
  • Understanding of shear stress calculations
  • Familiarity with thread geometry and dimensions
  • Knowledge of hydraulic press mechanics
  • Access to resources like the Machinery Handbook
  • Research the mechanics of shear stress in threaded connections
  • Learn about the properties and applications of shouldered bolts
  • Explore the use of the Machinery Handbook for engineering calculations
  • Investigate stress concentration factors in mechanical design
Mechanical engineers, design engineers, and safety engineers involved in the design and analysis of hydraulic systems and threaded connections.
inquist
Shear thread formula?
my group has been told to figure the shear stress of a thread for a hydraulic press which pushes at 100t, we have figured it will pull at 30t using the ratio of the areas from the pistions.
just we need to figure the shear stress on the thread if it was to pull. we don't know what formula to use.
any help would be appreciated.
Does one have access to a Machinery Handbook? Perhaps one can try the library or one's department.
Here is one example.
http://www.roymech.co.uk/Useful_Tables/Screws/Thread_Calcs.html
and another
http://www.tribology-abc.com/calculators/e3_6e.htm
But the answer will be geometry dependent, and I imagine the thread is rather thick for a hydraulic press, as compared to a bolt or fastening screw.
Quick and dirty answer from http://www.efunda.com/forum/show_message.cfm?start=1&thread=18428&id=18435
A = K*Pi*D*T where D is the thread minor diameter, Pi = 3.14, T is the thread engagement, and K is a function of the internal thread contact, which in worst case is 0.5 for square threads. Set stress equal to shear yield stress and solve for force, P.
But do it right!
Why would you ever load threads in shear? Considering stress concentration risers you are always better off using shouldered bolts whenever possible. This is especially true when extremely large forces and/or health and safety risks are present.
13K
10K
