What is the Correct Relationship Between r and y in This Related Rates Problem?
  • Thread starter Thread starter Saladsamurai
    Related rates
The discussion revolves around a related rates problem involving the volume of water in a spherical container, where participants explore the relationship between the variables r (radius) and y (height of water). The original poster expresses concern about establishing the correct relationship between these variables to differentiate the volume equation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss differentiating the volume equation with respect to time and the implications of the relationships between r and y. Questions arise about whether to express one variable in terms of the other and the relevance of special cases in the context of the problem.
Some participants have offered guidance on differentiating the volume equation and checking results against special cases. There is an ongoing exploration of the relationships between the variables, with no explicit consensus reached on the best approach.
Participants note that the problem involves specific values, such as the radius of the sphere and the rate of change of volume, which may influence the differentiation process. There is mention of the complexity involved in expressing y as a function of V.
Saladsamurai
Implicit Differentiation
I have a diagram and I am using the info given to establish some relationships. I guess my main concern is whether I have established a correct relationship between r and y as to eliminate one of them. If I have, am having trouble differentiating the following
V=(pi/3)y^2(3r-y) which after substitution looks like
V=(pi/3)y^2(3sqrt(26y-y^2)-y)
Does this look like I am on the right track to find both dy/dt and dr/dt at y=8...or am I just making things difficult?
Casey
Why don't you calculate V' ?
Obviously V' should be related to y'.
Actually you should have V' = S y', where S is the free surface of water.
Indeed: if the level decreases by dy, the volume decreases by dV=S dy.
But you should not worry to calculate S geometrically, just differentiate V and see what you get.
If you like (geometry), you can also check that your result fits with the free surface.
Also, don't forget to check your result on special cases!
If y=0 you should have V'=0 too, since you are in the bottom of the (spherical) container.
Similarly, for y=2R, you should also get V'=0 since the "ceiling" is very small then.
Note:
Expressing y as a function of V to solve this problem is much more complicated.
You would have to solve of polynomial of degree 3!
I am not sure that I follow. I don't think that any special cases apply here do they? I am only trying to calculate dy/dt and dr/dt. I am given that that dV/dt is 6; V=(pi/3)y^2(3r-y); the radius of the sphere is 13, but when the water reaches height y=8, the water's radius=r.
Shouldn't I differentiate the formula for V? Since dV/dt=dy/dt*dV/dy, thus I can solve for dy/dt?
But, to differentiate V with respect to y, don't I have to rewrite r in terms of y? (or vice versa and solve for dr/dt?)
In this expression:
V = pi/3 y²(3R-y)
only y is a function of time, other things are constant.
Calculate dV/dt = dV/dy dy/dt, simplify your expression and go back to my first answer.
If you wish post your result for dV/t, I will check if it is ok, I will first check that it fits the special cases.
From you result, you will be able to solve for dy/dt.
I go to bed now and will come here again tomorrow.
[tex]If R=13 then, V=\frac{\pi}{3}y^2(39-y)[/tex]
[tex]\rightarrowV=13{\pi}y^2-\frac{\pi}{3}y^3[/tex]
so [tex]\frac{dV}{dy}=26{\pi}y-{\pi}y^2[/tex]
at [tex]y=8, \frac{dV}{dy}=144{\pi}[/tex]
[tex]\frac{dy}{dt}=\frac{\frac{dV}{dt}}{\frac{dv}{dy}}=-\frac{6}{144/{pi}}=-\frac{1}{24\pi}}[/tex]
which when I add the correct units yields the correct answer. I am not sure what the problem was but I figured it out and made my first attempt at using Latex. (I am prouder of the latter!:biggrin:)
By the way, how do I get a space in between "If" and "R" in If R=... using Latex?
Thanks Labs,
Casey
Normal typewriting in Latex is a mystery for me, I am used to write formulas, nothing else.
Your expression [tex]\frac{dV}{dy}=26{\pi}y-{\pi}y^2[/tex] give zero for y=0 and for y=2R=26, which is a good indication that you got the right result.
Why did you put the numeric values right from the begining?
Would it not have been more funny if you had the general expression for any value of R? You could have seen it should be proportional to y(2R-y) of course.
Anyway, you got it apparently!
  • · Replies 24 ·
  • · Replies 30 ·
