What PSI Results from an 8 lb Thrust in a Closed Container?
  • Context: Undergrad
  • Thread starter Thread starter Subaru_STI
    Pressure Thrust
The discussion revolves around calculating the pressure inside a closed container when an RC electric ducted fan engine produces 8 lb of thrust. The scope includes theoretical considerations of thrust, pressure differentials, and practical applications in a supercharger design.
  • Technical explanation, Conceptual clarification, Experimental/applied
  • One participant asks for the PSI resulting from 8 lb of thrust in a closed container, indicating a continuous operation of the engine.
  • Another participant notes that the pressure depends on the size of the container and suggests dividing the force by the area for a coherent stream of air impacting a wall.
  • A participant mentions their intention to create a battery-powered supercharger for a car, seeking a rough estimate based on this application.
  • A later reply reiterates the initial question and clarifies that the ducted fan acts as a compressor, proposing that the pressure can be calculated by dividing the thrust by the cross-sectional area of the duct, providing an example calculation based on a 4-inch diameter duct.
Participants do not reach a consensus on the exact pressure calculation, as the discussion includes varying assumptions about the container size and the nature of the airflow. Multiple views on the relationship between thrust and pressure remain present.
Assumptions about the container's dimensions, the nature of the airflow, and the specific configuration of the ducted fan are not fully resolved, which may affect the pressure calculations.
Subaru_STI
If I have a RC electric ducted fan engine blowing at 8 lb of thrust into a closed container, what PSI would it be inside of the container, (when the engine is runny continuously)?
Thanks
Depends on the size of the container and how the stream is captured. For a coherent stream of air hitting a wall, you can take the force and divide by the area.
I am basically making a battery powered supercharger for a car. the motor will be fitted into the intake tube.. can you get a rough idea from that?
Your statement implies that there's a net pressure differential between the contaniner and the outside air that results in 8 lbs of force at the fan. Also, there's no blowing, the ducted fan is acting as a compressor if it's output is going into a closed container. The pressure would be 8 lbs divided by the cross sectional area of the duct containing the fan. If the duct has a diameter of 4 inches, then the area of the duct is pi x r^2 = pi x (2)^2 = 12.566 in^2. Pressure would be 8 lbs / 12.566 in^2 ~= .636 psi.
  • · Replies 55 ·
  • · Replies 26 ·
9K
  • · Replies 21 ·
