Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Angle between vectors Share It Thread Tools Search this Thread image
Old Aug2-07, 07:21 AM                  #1
t_n_p
t_n_p is Offline:
A little left of field this question..
3. The attempt at a solution
I'm unsure more with the wording of this question if anything rather than the method of how to go about it. How would I go about finding the vector that represents a "half Inuit, half Bantu" population?
Old Aug2-07, 07:27 AM                  #2
christianjb
christianjb is Offline:
Take the average of the two columns.
Old Aug2-07, 07:30 AM                  #3
t_n_p
t_n_p is Offline:
Seems pretty logical/right, but best to wait for another person to confirm this is 100% right.
Thanks christianjb!
Old Aug2-07, 08:45 AM                  #4
Gib Z
Gib Z's Avatar
Gib Z is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Personally I would go for the geometric mean of the 2 columns, rather than arithmetic mean (assuming the numbers represent probabilities?), but It could still be correct to say arithmetic mean.
Old Aug2-07, 09:46 AM                  #5
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Since they are talking about these as vectors, I would interpret "half Inuit, half Bantu" to mean LaTeX Code: (1/2)\\vec{I}+ (1/2)\\vec{B} , adding 1/2 of each vector. of course, that is the same as taking the arithmetic average (mean).
Old Aug3-07, 04:51 AM                  #6
t_n_p
t_n_p is Offline:
I guess it's the average of two then. Thanks guys
Old Aug6-07, 07:11 PM                  #7
t_n_p
t_n_p is Offline:
Managed to figure that one out after using the mean of the two but got stuck soon after on this question.
Amongst all possible combinations that are mix of Inuit and Bantu, find the mix
that is closest to the English population. (Hint: Set up things such that the
infinitely many different possible mixed populations correspond to a vector that depends on a variable, say t.)
With the hint, I'm thinking I should use Gaussian elimination somehow? Is there a better method?
Old Aug7-07, 08:26 PM                  #8
t_n_p
t_n_p is Offline:
Halls, I can't see your Latex graphic!
Old Aug8-07, 05:54 AM                  #9
HallsofIvy
PF Mentor
I would interpret a "mix" of Inuit and Bantu vectors as LaTeX Code: t\\vec{I}+ (1-t)\\vec{B} where t is a number between 0 and 1. That will give the "infinitely many different possible mixed populations" they are talking about. Find the t that minimizes the distance between that and LaTeX Code: \\vec{E} .
Old Aug8-07, 06:36 AM                  #10
t_n_p
t_n_p is Offline:
hmmm, not sure how I would go about finding a t value that minimizes distance....
Old Aug10-07, 01:03 AM                  #11
t_n_p
t_n_p is Offline:
bump*********
Old Aug10-07, 06:24 AM                  #12
HallsofIvy
PF Mentor
Do you know how to find the distance between two vectors: ||u- v||.
That will be quadratic in t and then complete the square.
Old Aug10-07, 06:28 AM                  #13
t_n_p
t_n_p is Offline:
I don't really understand, can you elaborate?
Old Aug10-07, 06:43 PM       Last edited by EnumaElish; Aug10-07 at 06:47 PM..            #14
EnumaElish
EnumaElish's Avatar
EnumaElish is Offline:
Recognitions:
I think Halls was proposing to write down the expression for ||E - (tI - (1-t)B)|| then take its derivative w/r/t t and set to zero.
http://en.wikipedia.org/wiki/Distance#Geometry
Old Aug10-07, 09:36 PM                  #15
t_n_p
t_n_p is Offline:
woah!
So first I find the distance between the two vectors, but which two vectors in particular? My common sense tells me between vector E and vector (tI - (1-t)B. But how do I interpret (tI - (1-t)B?
Slightly confused!
Old Aug11-07, 12:12 AM                  #16
learningphysics
learningphysics is Offline:
Recognitions:
I'm not sure calculating the magnitude of the difference between the vectors will give the right solution... it is the angle that needs to be minimized...
calculate:
H = tI + (1-t)B
t is just a scalar, write out I and B in (x1,x2,x3,x4) form... then you should be able to calculate H and write it in (x1,x2,x3,x4) form.
Then do the dot product between E (english) and H... you have a formula for dot product that relates it to the magnitudes and the angle between the vectors...
image image
Reply
Thread Tools
Similar Threads for: Angle between vectors
Thread Thread Starter Forum Replies Last Post
Signed angle between vectors daviddoria Linear & Abstract Algebra 12 Apr10-08 06:46 PM
Angle between vectors help rafael_josem Introductory Physics 0 Sep26-07 02:49 PM
Angle Between Vectors needhelp83 Introductory Physics 10 Oct26-06 06:13 PM
vectors and angle.... lmf22 Introductory Physics 4 Oct8-04 08:27 PM
Finding the angle between 2 vectors PinkFlamingo Introductory Physics 5 May17-04 08:20 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
