Current-Carrying Wire/Magnet Question
  • Thread starter Thread starter bagheera
The discussion centers on the behavior of a current-carrying wire placed between magnetic poles, specifically addressing the direction of force acting on the wire and its rotational behavior. The consensus is that side X of the wire will be forced upwards due to the application of the right-hand rule. Additionally, it is concluded that the wire will not rotate indefinitely; it will stop when it reaches a position where the magnetic force changes direction, primarily influenced by gravity.
  • Understanding of the right-hand rule in electromagnetism
  • Basic knowledge of magnetic fields and forces
  • Familiarity with torque and rotational motion concepts
  • Awareness of gravitational effects on physical objects
  • Study the right-hand rule in greater detail to apply it effectively in various scenarios
  • Research the principles of torque and how they affect rotational motion in magnetic fields
  • Explore the interaction between magnetic fields and electric currents in depth
  • Investigate the effects of gravity on rotating systems in physics
Students studying physics, particularly those focusing on electromagnetism and mechanics, as well as educators seeking to clarify concepts related to magnetic forces and current-carrying conductors.
bagheera
http://img227.imageshack.us/img227/4773/picture286zs7.png
The illustration shows a current-carrying wire between magnetic poles. The arrows in the illustration show the direction of the current.
A. In the illustration above, will side X be forced up or down?
B. How far will the wire rotate before it stops? Why?
I used the right-hand rule for the first, but I have no idea how to solve the second.
The answer to A is up, correct? I tried to use the right-hand rule and it seems correct, but could someone confirm I'm on the right track?
I have no idea how to solve the second... I would assume that it will not be able to infinitely rotate, right?
Thank you soooo much for any help you could provide. :approve: Physics is not my strong subject... T.T
Do you have to consider the magnetic field of the magnet only, or do you have to include interaction between the wire itself?
In my opinion (I've used the right hand also), the wire won't experience a vertical force at all.
When the wire turns and goes beyond 90 degrees, the force changes direction... this causes it to stop. Thats what you have to find out. The only vertical force here is gravity.
