Evaluate the ground state energy using the variational method
The problem involves evaluating the ground state energy of a potential defined as V(x) = k|x| for x in the interval [-a, a], with V(x) being infinite outside this range. The original poster is using the variational method with a trial wave function of the form ψ(x) = A/(x² + c²).
  • The original poster attempts to normalize the trial function and questions the correctness of their approach, specifically regarding the integral involved. Some participants confirm the normalization step but seek clarification on the results obtained from Mathematica, particularly regarding the appearance of imaginary components in the output.
The discussion is ongoing, with participants clarifying the normalization process and exploring the implications of the results from Mathematica. There is a focus on understanding the nature of the trial function and the assumptions made in the problem statement.
Participants note the assumption of a = ∞ as stated in the paper, which is a point of confusion for some. There is also a mention of the need for clarity in presenting the complete problem statement without summarization.
Urvabara
[tex]V(x) = k|x|, x \in [-a,a], V(x) = \infty, x \notin [-a,a][/tex]. Evaluate the ground state energy using the variational method.
[tex]a = \infty[/tex] and [tex]\psi = \frac{A}{x^{2}+c^{2}}[/tex].
[tex]1 = |A|^{2}\int_{-a}^{a}\frac{1}{(x^{2}+c^{2})^{2}}\,\text{d}x.[/tex] Is this a correct way to start? How can I calculate this? I used Mathematica, but it only gives some weird-looking answers.
Yes, that's how you normalize the trial function. And what do you mean by "weird"?
Also, why do you say a=infty?
This is what I put:
In[2]:=
\!\(∫\_\(-a\)\%a\( 1\/\((x\^2 + c\^2)\)\^2\) \[DifferentialD]x\)
This is what I got:
Out[2]=
\!\(2\ a\ If[Im[c\/a] ≥ 1 || Im[c\/a] ≤ \(-1\) || Re[c\/a]
≠ 0, \(c\/\(a\^2 + c\^2\) + ArcTan[
a\/c]\/a\)\/\(2\ c\^3\),
Integrate[1\/\((c\^2 + \((a - 2\ a\ x)\)\^2)\)\^2, {x, 0, 1}, \
Assumptions \[Rule] Re[c\/a] \[Equal] 0 && \(-1\) < Im[c\/a] < 1]]\)
I do not understand. What are those imaginary things?
In the paper, it says: "Assume that [tex]a=\infty[/tex] and use the trial [tex]\psi(x)=...[/tex]."
Urvabara said:
This is what I put:
In[2]:=
This is what I got:
Out[2]=
I can't read that easily, but I believe it allows for values of c that are not real. For the problem, you could chose to limit yourself to real c.
Then please write this down as part of the question.Always write down the complete question. Do not summarize or reword in any way.
  • · Replies 20 ·
