| Thread Closed |
Ideal Diesel Cycle Help?? |
Share Thread |
| Aug3-07, 12:01 PM | #1 |
A 5-liter 10 cylinder, 4 stroke engine to produce 550kw at 12000rpm. Compression ratio 18, cut-off ratio 2.5. Air enters with 280K and 170Kpa, after passing two-stage turbo charger and intercooler. Using variable specific heats. (a) find gas temperature after combustion (b) the approximate rate of consumption of diesel fuel (c) the air-fuel ratio (d) the volumetric efficiency of the engine. 2. Relevant equations LHV(diesel)=43.1 Mj/kg 3. The attempt at a solution I have solved part (a), what formulas do ii have to use for the rest of the parts. |
| Aug5-07, 09:32 AM | #2 |
Admin
One should have some value for the 'heat or energy content' (kJ/kg or Btu/lbm) of the diesel fuel in order to approximate the rate of consumption of diesel fuel.
Then with the mass flow rate of air and mass flow rate of fuel . . . . What does one's textbook mention in regard to fuel energy content? Presumably there are examples of fuel consumption calculations. |
| Thread Closed |
Similar discussions for: Ideal Diesel Cycle Help??
| Carnot Cycle, how ideal is it? | Introductory Physics Homework | 9 | ||
| ideal gas using carnot cycle | Introductory Physics Homework | 5 | ||
| Diesel Cycle Help1. | Mechanical Engineering | 4 | ||
| Diesel Cycle - Heat Engines - Thermo. | Mechanical Engineering | 7 | ||
| Diesel Cycle - Heat Engines - Thermo. | General Engineering | 5 | ||
