Thread Closed
Simple Matrix algebra
Share Thread Thread Tools
Aug4-07, 05:55 AM   #1
Recognitions:
Gold Membership Gold Member
On page 44 of Ryder's QFT, near the bottom of the page, it says:
Quote by Ryder
it is straightforward to show, by writing out all four components of (2.94), that the eigenvalues of E are:
[tex]E = +(m^2 + p^2)^{1/2}[/tex] twice,
[tex]E = -(m^2 + p^2)^{1/2}[/tex] twice,
2. Relevant equations
Equation (2.94) is
[tex](\gamma^{\mu}p_{\mu} - m)\psi(p) = 0[/tex]
3. The attempt at a solution
Writing out all four components, and then taking the determinant and setting to zero, I get:
[tex]m^4 - (E^2 - p^2)^2 = 0[/tex] or [tex]m^4 = (E^2 - p^2)^2[/tex]
Taking the square root once:
[tex]\pm m^2 = E^2 - p^2[/tex] or [tex]E^2 = p^2 \pm m^2[/tex].
And taking the square root again:
[tex]E = \pm(p^2 \pm m^2)^{1/2}[/tex]
and I end up with different eigenvalues than I am supposed to.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Aug6-07, 11:54 AM   #2
How did you calculate the determinant? I calculated it with some formulae, and I got only two eigenvalues. Maybe you should try using a software like mathematica to calculate it by brute force.
Let just hope that your Dirac matrices are same as mine. I used
then I used
[tex](\sigma_\mu p^\mu)(\sigma'_\mu p^\mu) = p_\mu p^\mu[/tex]
where [tex]\sigma^\mu = (1, \sigma^i)[/tex]
where [tex]\sigma'^\mu = (1, -\sigma^i)[/tex]
[tex]\sigma^i[/tex] are Pauli matrices.
I got [tex]m^2 = E^2 - p^2[/tex].
Aug6-07, 12:59 PM   #3
Recognitions:
Quote by kakarukeys View Post
Thanks for taking a look at this kakarukeys. I don't think your equation could be the determinant since there are supposed to be 4 eigenvalues, and your equation is only quadratic in E.
Aug6-07, 09:33 PM   #4
At one stage of my calculations, I had ()^2 = 0 implies () = 0
so a 4th order eq became quadratic eq
Aug7-07, 06:24 AM   #5
Mentor
So, each of your distinct eigenvalues is repeated.
Aug7-07, 12:18 PM   #6
Recognitions:
Thanks kakarukeys. I was making two errors. First of all, I had the wrong matrix for [tex]\gamma^0[/tex], and second of all, I was calculating the determinant incorrectly. With your help, I now get the following determinant:
[tex](E^2 - m^2 - p^2)^2[/tex] and setting this to zero gives the correct eigenvalues. Thanks George to you as well. Actually, I gathered the same meaning from message #4 as you did, but it's good to know that you have my back.
Thread Closed
Thread Tools
Similar Threads for: Simple Matrix algebra
Thread Forum Replies
Simple matrix algebra Advanced Physics Homework 6
Matrix Algebra Introductory Physics Homework 1
Matrix algebra Introductory Physics Homework 1
Eigenvectors and using them in matrix algebra. Linear & Abstract Algebra 1
Matrix Algebra Biology 5
