Can Space Tear? Examining the Elasticity of Space and Time
  • Context: Graduate
  • Thread starter Thread starter Mike2
    Space
The discussion centers on the concept of whether the fabric of space or space-time can rip or tear, exploring its elastic properties and implications. Participants examine theoretical frameworks, topological considerations, and the relationship between elasticity and the structure of space-time, including references to general relativity and string theory.
  • Some participants propose that the fabric of space has elastic properties, suggesting that it may stretch and potentially rip under certain tensions.
  • One participant speculates that the tearing of space could relate to the vibrational modes of strings, implying a connection between the two concepts.
  • Topological considerations are raised regarding whether an expanding closed manifold can tear and form boundaries, with questions about the mechanisms preventing instantaneous changes in expansion rate.
  • Participants discuss the possibility of a "big rip" scenario as described in the phantom energy model, though opinions on the relevance of string theory to this end vary.
  • There is speculation about the tendency of points in space to adhere to one another and how this might influence the curvature of space and the potential for tears to form.
  • One participant references Brian Greene's assertion that general relativity implies the fabric of space cannot tear, questioning the assumptions underlying this claim and suggesting that metrics on manifolds with boundaries could be valid.
  • Another participant challenges the interpretation of general relativity, arguing that it does not definitively state that space cannot tear and that singularities in black holes might represent a form of boundary or tear in space-time.
  • There is mention of a potential quantum gravity theory that could provide insights into the nature of spacetime tearing, suggesting a more complex structure than classical theories allow.
Participants express a range of views on the nature of space-time and its potential to tear, with no consensus reached. Some agree with Greene's interpretation of general relativity, while others contest it, leading to a debate on the implications of boundaries and singularities in the context of space-time.
Limitations include unresolved assumptions about the nature of elasticity in space, the definitions of adherence between points in space, and the implications of topological properties on the expansion of manifolds. The discussion also reflects varying interpretations of general relativity and its predictions regarding the smoothness of space-time.
Mike2
Can the fabric of space, or space-time, rip and tear? It would seem that the fabric can stretch, that it has some sort of elastic property. Does elasticity imply a tension at which it can rip or tear? Would that ripping tension be the tension of a string?
Thanks.
If strings are the boundary of space created by space tearing, perhaps the violence of the tearing of the fabric of space is what sets the vibrational modes of the strings.
Are there any topological consideration for an expanding closed manifold to tear and form a boundary?
http://arxiv.org/abs/astro-ph/0302506
this site discuses the phantom energy model and the possibility that
our end will a "big rip", i don't know about a string model for this end
but then i know nothing about SF.
If there were no resistance to the expansion of the initial manifold, then the expansion would almost immediately accelerate to an infinite speed. So there must exist some mechanism to prevent instantaneous change in expansion rate. I'm wondering what topological properties might be involved. It seems as though there are two tendencies here, one is the tendency of the initial compact dimension to uncurl so that the curvature of space would flatten out, and the other is for points in space to adhear to one another (whatever adhear means, maybe some sort of elastic property).
I can imagine a situation where the tendency for the curvature of space to flatten out might overcome the tendency of points in space to adhear to each other so that eventually tears in the fabric of space form.
Might this all be due to one overall effect... I wonder if the tendency of points in space to adhear might be responsible for curvature to flatten out. I imagine some elastic material that is bent having a tendency to flatten out.
OR,... perhaps there is a positive divergence at every point of space (not in particles) that acts as a source of more space. Certainly the very first point of space was divergent since it expanded. I imagine that an outward pressure (of space) would have a tendency to make adjacent points travel in straight lines so that curled up space would flatten out. Does GR predict a positive divergence of space? Would such a divergence be proportional to the size of the universe? If the density of space can change, then it can become zero, right?
Brian Green, in his book, The Elegant Universe, page 263, says, "Einstein's general relativity says no, the fabric of space cannot tear. The equations of general relativity are firmly rooted in Riemannian geometry and, as we noted in the preceding chapter, this is a framework that analyzes the distortions in the distance relations between nearby locations in space. In order to speak meaningfully about these distance relations, the underlying mathematical formalism requires that the substrate of space is smooth -..."
In other words, GR studies a metric on a manifold. My question is... can't you just as easily have a metric on a manifold with a boundary? If so, then that boundary can be distributed as well, can't it?
Whoa! I love some of these olde threads! :-D
If anyonez still readin' here's another opinion:
Re: ""Einstein's general relativity says no, the fabric of space cannot tear."
* You shouldn't read pop sci literature in such a serious way. GR does not say any such thing! GR ASSUMES a Riemannian geometry. It cannot therefore be said to predict spacetime is smooth. Greene would know this, but presummably was writing for a lay readership and so did not quibble about such nuances.
* In reply to,
...can't you just as easily have a metric on a manifold with a boundary?
Yes, that's perfectly ok. Far from such boundaries GR would be recovered one expects. In fact, a black hole is essentially such a simple point boundary, so we already know how to handle this type of topological defect in GR. How? Ignore it - as most textbooks do! Haha! ;-D
Textbooks tell us that GR "blows up" or becomes unphysical for black hole singularities. This may well be true, but you could always argue that GR doesn't become unphysical, in fact it is still entirely fine as a classical theory, it's just that it could be said to predict a point-like tear in spacetime = the singularity, which is now "outside" the physical universe, hence can be ignored. Only the effects of the singularity on the surrounding spacetime are important and physical.
Maybe I'm showing my bias, but I've always thought it silly of people to say GR is incomplete because it predicts a divergent curvature and mass-energy density in a black hole. I don't think there is anything wrong with infinities appearing, provided they are appropriately handled.
Having said that, I suppose a putative quantum gravity theory would have other things to say about spacetime tearing and so forth, a la the foamy spacetime picture - it could be interpreted perhaps as a massive amount of tearing! (As previous posts have suggested in other terms.)
KOSS, please don't post on the tail of old threads like this. It's referred to as necroposting, and it's frowned on here.
-Ben
  • · Replies 88 ·
10K
  • · Replies 37 ·
  • · Replies 48 ·
