| Thread Closed |
Galois extension of a field with Characteristic 0 |
Share Thread |
| Aug6-07, 06:13 PM | #1 |
This is something I've been trying to work on on my own for the past few days but I'm not sure how to approach it.
My Question: a. Let E be a Galois extension of a field F with characteristic 0. Prove that there is a unique smallest subfield K such that [itex] F \subseteq K \subseteq E [/itex], K is normal over F and E is subradical over K. [One needs the following result: Let [itex]A[/itex] and [itex]B[/itex] be solvable subgroups of a group [itex]G[/itex] and suppose that [itex]A[/itex] is normal in [itex]G[/itex]. Then [itex]AB[/itex] is solvable.] b. Let f be an irreducible polynomial over [itex]\mathbb{Q}[/itex] which has degree 5 and at least two complex roots. Prove that [itex]Gal(f)[/itex] has order 10, 20, 60, or 120. Thanks in advance for any kind of direction that you can provide me with... |
| Aug7-07, 04:15 PM | #2 |
Recognitions:
what does smallest mean? the intersectiuoin of all such thigns? or smallest degree?
and are your extensions of finite degree? so i guess you are claiming there is a unique largest normal solvable subgroup of a group. your description majkes it fairly obvious how to proceed. |
| Thread Closed |
Similar Threads for: Galois extension of a field with Characteristic 0
| [SOLVED] extension field | Calculus & Beyond Homework | 2 | ||
| field extension | Calculus & Beyond Homework | 1 | ||
| [SOLVED] polynomials/ galois field question | Set Theory, Logic, Probability, Statistics | 3 | ||
| An extension of the concept of a tensor field | Differential Geometry | 2 | ||
| Galois Extension field properties | Linear & Abstract Algebra | 1 | ||
