Uncovering the Distribution of Bloomed Charge with KODAK KAF-0402
The discussion revolves around the distribution of Bloomed Charge in the KODAK KAF-0402 CCD sensor, focusing on the relationship between dark current, dark noise, and blooming phenomena. Participants explore technical aspects related to CCD technology, including charge distribution, measurement techniques, and the implications of dark current on blooming.
  • One participant suggests that the distribution of Bloomed Charge is related to dark current and dark noise, proposing that variations in dark current can affect blooming.
  • Another participant argues that blooming is primarily caused by overloading CCD pixels with light, not dark current.
  • A different viewpoint explains that blooming involves charge flowing out of a pixel into surrounding areas and mentions anti-blooming drains as a method to prevent this, although they note that scientific CCDs like the KAF-0402 do not include these due to efficiency concerns.
  • One participant raises a question about the relationship between dark current and blooming, suggesting that overexposed pixels may exhibit increased dark current, complicating the analysis of blooming distribution.
  • Concerns are expressed regarding the interpretation of pixel charge values obtained from MATLAB, with confusion about the relationship between these values, saturation signals, and the concept of ADU (Analog to Digital Units).
  • Another participant mentions that the increased rate of dark current can indicate where blooming has occurred and suggests using dark frames taken before and after blooming for analysis.
  • A participant inquires about techniques to measure the gain of the CCD, indicating they have a series of dark images with varying integration times.
Participants express differing views on the relationship between dark current and blooming, with no consensus reached. Some agree that dark current may play a role in understanding blooming, while others maintain that blooming is primarily a result of light overload. The discussion on pixel charge values and measurement techniques also reveals uncertainty and differing interpretations.
Participants mention the potential for shot noise statistics affecting dark count measurements and the implications of software scaling on pixel values. There is also a lack of clarity regarding the units of measurement and how to accurately interpret the data obtained from the CCD.
This discussion may be useful for individuals working with CCD technology, particularly in the context of astrophysics or imaging applications, as well as those interested in the technical aspects of charge distribution and noise analysis in CCD sensors.
pavement
Hi guys
I was getting into a hobble with my project.my tutor said the aim of my project is to find out the distribution of Bloomed Charge, but i only have several dark images associated with the readout of KODAK KAF-0402. I supposed it was related to Dark current and Dark Noise. Because the rate of Dark current can predict, and the variation rate of Dark current of each pixel is the main point which will affect the distribution of Bloomed Charge.
SO am I right?:confused::confused::confused: Any body knows a lot about CCD technology can give me a help. thank you!:smile:(I got a lot querys, if you can help i want to use msn for more communication. appreciated for your help.)
I don't think blooming has anything to do with dark current. Isn't blooming from overloading the CCD pixels with too much light?
Blooming is charge flowing out of a ccd 'pixel' into surrounding areas.
You can prevent this with anti-blooming drains, electronic structures which carry away overflowing charge but scientific CCDs including the KAF-0402 don't have these beacuse they significantly reduce efficency.
The only relationship between blooming and dark current is that seriously overexposed CCD pixels can have raised dark current for some time afterwards. This is mainly a problem in cryogenic astronomical cameras.
The big book of CCDs is by James Janesick.
thank you for your reply guys! I know the blooming is because of overloaded from light. but the tutor want me to indicate the distribuation of ccd bloomed charge.
just like MGB said the dark current value will raise, and also the dark current noise can be predicted. so if the CCD just exposure equaly, the pixel contain more dark current noise will possibily blooming first right? so we can indicate the distribution of bloomed charge then, right? i hope I'm right! if not i really don't know how to write my project report.
BTW the value of the pixel charge i read from the image by MATLAB is what?
my tutor said it's quantum and he said quantum=52 electrons? I thought it's wrong.because the saturation signal is100000 electrons. but the biggest value i got is 4095,so 4095x52= 212940 electrons, head and shoulders above saturation signal.How could that happened? i thought the maximal value of charge should equal or less saturation signal right? impossible more than it.so what's the unit of the value i got from the image by matlab? ADU? if it's ADU what about gains of ADU? I just want to know how many electrons it contained with each pixels.
thank you for your answers? appreciate
The increased rate of dark current can show where blooming occurred, presumably you have before and after blooming dark frames?
Remember that the dark count has shot noise statistics so has a root(n) uncertainty.
The 4095 could be due to some scaling in the software or possibly a negative value caused by subtracting two images.
The gain of the ccd (the 52adu/e) depends on both the chip and the readout electronics, there is a technique to measure it statistically if you have a sequence of dark images with different exposure times.
Can you tell me more about that technique? Actually I got a sequence of dark images with 100ms,200ms,300ms,500ms,800ms,1800ms,4800ms,9800ms intergration time dark images. so how to measure the gain of it?
  • · Replies 152 ·
12K
