What Happens When You Identify Points on a Torus and a Rolled Cylinder?
  • Context: Graduate
  • Thread starter Thread starter ehrenfest
    Identification
The discussion revolves around the identification of points on a torus and a rolled cylinder, specifically examining the implications of different identification rules on the resulting geometric spaces. Participants explore the nature of these spaces and their dimensional characteristics.
  • One participant questions the nature of the space resulting from the identification (x,y) ~ (x+2piR, y+2piR) and how it differs from the identification (x,y) ~ (x+2piR, y) and (x,y) ~ (x, y+2piR), which is described as a two-dimensional torus.
  • Another participant suggests that the resulting space is a cylinder rolled up along the diagonal.
  • A participant seeks clarification on what is meant by "the diagonal" in this context.
  • One participant indicates that the diagonal refers to a specific direction in the coordinate system, although this is not visually supported by an attachment that was intended to be shared.
  • There is a discussion about moving along the diagonal by taking (x,y) to (x+a,y+a) and identifying after a = 2Pi, leading to a cylinder rolled along that diagonal.
  • A participant introduces a transformation to new coordinates x' and y' and questions how this affects the identification and the resulting geometry.
  • Another participant notes that for the identification to yield a cylinder, the parameter R must be the same for both x and y coordinates.
  • There is a suggestion that switching to light-cone coordinates results in a cylinder rolled around a different axis.
Participants express differing views on the nature of the resulting space from the various identifications, indicating that multiple competing interpretations exist without a clear consensus.
The discussion includes assumptions about the parameters involved in the identifications and the implications of coordinate transformations, which remain unresolved.
ehrenfest
What is the space resulting from the identification (x,y) ~ (x+2piR, y+2piR)? How is it different from the space resulting from
(x,y) ~ (x+2piR, y)
(x,y) ~ (x, y+2piR), which is a two-dimensional torus (a donut)
It's a cylinder, rolled up along the diagonal.
What diagonal?
I'd say the diagonal indicated on the attachment (up to symmetry :-p)
Sorry, I don't see any attachment. Was that just a joke?
No, I forgot to click upload. Apparently you posted while I added it.
(BTW: Post [itex]13^2[/itex] for me)
[itex]13^2[/itex]
Why would you ask me to post that?
He meant he hit post #169, he did not want you to post anything.
Take (x,y) to (x+a,y+a) and you move up parallel to the diagonal between the x and the y axis. if you identify after a = 2Pi then you get a cylinder rolled along that diagonal.
ehrenfest, what happens if you switch to coordinates x' = (x + y)/sqrt(2) and y' = (x - y)/sqrt(2)?
I see why it is different than the other identification! The R has to be the same for both x and y.
If you switch to light-cone coordinates, then it is a cylinder rolled around the y' axis, right?
  • · Replies 33 ·
  • · Replies 0 ·
