Reynolds Transport Theorem and Conservation Laws.
The discussion revolves around the application of the Reynolds Transport Theorem (RTT) to various physical quantities, particularly focusing on the treatment of position as a quantity in fluid dynamics. Participants explore the implications of applying RTT to position and the resulting mathematical expressions, questioning the validity of certain assumptions and interpretations.
  • One participant applies RTT to the physical quantity of position, leading to a conclusion that suggests velocity must be zero, which they later identify as incorrect.
  • Another participant challenges the notion of applying RTT to position, arguing that position cannot be transported and that the integral of position over volume does not yield zero.
  • A participant clarifies their earlier statement about the time-derivative of the integral, acknowledging a misunderstanding regarding the integral's behavior over time.
  • Discussion includes the importance of the frame of reference in applying RTT, with some participants asserting that the control volume must be treated as transported by the fluid rather than fixed in space.
  • One participant emphasizes that RTT pertains to physical properties within a control volume, suggesting that location is not a physical attribute relevant to RTT.
  • Another participant notes that velocity should not be treated as a physical quantity in the context of RTT, highlighting the distinction between extensive and non-extensive parameters.
Participants express differing views on the appropriateness of applying RTT to position, with some arguing against it while others attempt to reconcile their interpretations. The discussion remains unresolved regarding the correct application of RTT to various physical quantities.
Participants indicate that misunderstandings about the frame of reference and the nature of physical quantities may have contributed to confusion in applying RTT. There are unresolved questions about the implications of source terms and the treatment of the control volume in relation to the fluid flow.
me24
The Reynolds Transport theorem (RTT) is usually applied to derive the conservation of mass, momentum and energy in a fluid. But when I try to apply the RTT to other physical quantities, I get weird results. Can anyone see where I'm going wrong?
As a simple example, take the physical quantity to be position, [itex]x[/itex]. Assume that the fluid density [itex]\rho[/itex] and velocity [itex]u[/itex] are independent of time, so that the time derivative of the volume integral [itex]\int \rho\,x\,dV[/itex] is zero. Applying the RTT to [itex]\rho\,x[/itex] gives,
[tex] \frac{\partial\,\rho\,x}{\partial\,t} + \nabla\cdot(\rho\,x\,u) = 0[/tex]
which can be rearranged as,
[tex] \left[\frac{\partial\,\rho}{\partial\,t} + \nabla\cdot(\rho\,u)\right]\,x<br /> + \rho\left\{\frac{\partial\,x}{\partial\,t} + u\cdot\nabla\,x\right\}[/tex]
This can be simplified by applying the mass equation,
[tex] \frac{\partial\,\rho}{\partial\,t} + \nabla\cdot(\rho\,u) = 0[/tex]
to yield the result,
[tex] \rho\,D_t(x) = 0[/tex]
where [itex]D_t[/itex] is the material derivative,
[tex] D_t = \frac{\partial}{\partial\,t} + u\cdot\nabla[/tex]
I think that [itex]\partial\,x/\partial\,t = 0[/itex] and [itex]\nabla\,x = I[/itex], where [itex]I[/itex] is the identity matrix, in which case the result simplifies to,
[tex] \rho\,u = 0[/tex]
This is incorrect:confused: [itex]u[/itex] does not need to be zero in order for the time derivative of [itex]\int \rho\,x\,dV[/itex] to be zero.
Saying that [itex]\int \rho\,x\,dV[/itex] is zero, makes no sense, especially if one expands dV into dx dy dz.
One cannot transport position.
See - http://en.wikipedia.org/wiki/Reynolds_transport_theorem
http://en.wikipedia.org/wiki/Advection
http://www.math.gatech.edu/~ho/Transphy.pdf - in the first paragraph [tex]\phi(x,t)[/tex] should read [tex]F(x,t)[/tex] which is the integrand in the equation below.
I think one is misapplying RTT.
The idea is that the rate of change in mass or other physical quantity like energy depends on the flow (transport) of mass or other physical quantity across the boundary of that volume. Position is not transported.
Astronuc, thanks for your comments. I was actually claiming that the time-derivative of [itex]\int \rho\,x\,dV[/itex] is zero, rather than the integral itself. I have subsequently realized that the time-derivative is not zero; perhaps that's what you meant? I'll give a longer reply in the next post.
Frame of reference for the Reynolds Transport Theorem
I think I've more or less got to grips with this problem. The probem arose because I misunderstood the frame of reference for the Reynolds Transport Theorem (RTT).
The RTT is simply obtained by differentiating a volume integral with respect to time,
[tex]\frac{d\,\int F(x,t)\,dV}{dt} = \int\,\frac{\partial\,F}{\partial\,t} + \nabla\cdot(F\,u)\,dV[/tex]
where [itex]u[/itex] is the velocity. It may be applied to any function [itex]F(x,t)[/itex], including [itex]F = x[/itex].
In order to convert the integral expression into a differential equation, one must make a physical postulate for the value of [itex]d\,\int F(x,t)\,dV\,/dt[/itex] . For the mass equation without source terms, it is set equal to zero. I think that source terms are equivalent to a non-zero value for the integral, though I haven't figured out a quantitative relation between the source and the integral.
A key point which is not made entirely clear in many discussions of the RTT is whether the control volume V is fixed in space, or whether it is transported by the fluid (so that it changes shape and volume) ?
Some texts, (eg Flanders, Differential Forms with applications to the physical sciences, Dover edition, pg 188), claim that V is fixed in space, and introduce the boundary-flux term [itex]\int \nabla\cdot(F\,u)\,dV[/itex] in a heuristic manner. Other texts claim that V is transported by the fluid, and obtain the boundary-flux term automatically when evaluating [itex]dV(t)/dt[/itex].
The correct answer is that the volume is transported, ie [itex]V = V(t)[/itex]. For a crisp derivation, try a text with a differential-geometry slant, eg Frankel, The Geometry of Physics, 1st edition, Sec. 4.3 and Eq. 3.17.
At the start of this thread, I set [itex]F = \rho\,x[/itex], and postulated that [itex]d\,\int \rho\,x\,dV\,/dt = 0[/itex]. This postulate was based on the incorrect fixed-volume frame. If one adopts the correct transported-volume frame, one sees that as the volume is transported from one location to another, the average value of [itex]x[/itex] within the volume will change, ie [itex]x = x(t)[/itex], and hence the integral is time-dependent and its time-derivative is non-zero.
I was careless. I focussed on the integral, rather than the time derivative thereof. The use of x (location) still does not make sense though.
Please refer to this discussion - http://en.wikipedia.org/wiki/Physical_quantity
Location is not a physical attribute, but size (length) is.
RTT is about the change of a physical property within a control volume.
I'll comment on the other post later.
I agree with Astronuc. You are transporting something. Velocity is not a physical something. I would suggest you read through a proof of RTT because you are going to take the dot product of b and the local velocity vector, i.e. the flux. It would make no sense to have the b = velocity and dot that with itself, would it? (b = an extensive parameter) [Velocity is not an extensive parameter].
  • · Replies 51 ·
10K
  • · Replies 32 ·
