Stationary point charge in increasing magnetic field
A stationary point charge placed in an increasing magnetic field experiences zero magnetic force due to the absence of velocity. According to the Lorentz force law, F = q (v × B), if the velocity (v) is zero, the force (F) remains zero regardless of changes in the magnetic field (dB/dt). The discussion emphasizes that magnetism is fundamentally linked to moving charges, and without movement, no magnetic interaction occurs.
  • Understanding of the Lorentz force law
  • Basic knowledge of magnetic fields and their properties
  • Familiarity with the concept of velocity in physics
  • Knowledge of electromagnetic theory
  • Study the implications of the Lorentz force law in various scenarios
  • Explore the relationship between electric fields and magnetic fields
  • Learn about the behavior of charges in non-uniform magnetic fields
  • Investigate the effects of velocity on magnetic force in practical applications
Physics students, educators, and professionals interested in electromagnetism and the behavior of charged particles in magnetic fields.
jimmyjets
hi everyone, if a stationary point charge is placed in an increasing magnetic field, is the force on the charge due to the magnetic field = 0?
because Fb = qv*B and v=0
then how would I derive the magnitude of the force on the charge due to the magnetic field with the magnetic field increasing at dB/dt?
thanks
The Lorrentz force law is actually
[tex]F = q \mathbf{v} \times \mathbf{B}[/tex]
It doesn't matter how your magnetic field is changing, if you have no velocity then you will not have any magnetic force acting on the object. Magnetism, from a relative standpoint, is the study of changing electric fields, which you don't have. It is the study of moving charges. If you don't have any current running through a wire, does it have a magnetic field? No, the charges aren't moving. The same thing applies here, your charge isn't moving so there isn't a field to interact with.
The same is true if the velocity and magnetic fields are parallel, no matter how fast the particle accelerates or how much the magnetic field changes the force will be zero.
  • · Replies 18 ·
