Experiment Volumetric analysis - Acid base
The discussion focuses on volumetric analysis involving the determination of the concentration of a mineral acid, HXO4, and the relative atomic mass of element X. The procedure includes titration of a solution containing 1.70 g of OH- ions per dm3 (KA2) with the mineral acid (KA1). Key calculations include determining the concentration of KA2 as 0.4 mol dm-3 and writing a balanced ionic equation for the neutralization reaction. Participants emphasize the importance of understanding the neutralization equation for accurate results.
  • Understanding of volumetric analysis techniques
  • Knowledge of acid-base titration procedures
  • Familiarity with stoichiometry and molarity calculations
  • Ability to write balanced chemical equations
  • Learn about the principles of acid-base titration
  • Study the concept of molarity and its calculations
  • Explore the process of writing balanced ionic equations
  • Investigate the properties of phenolphthalein as an indicator
Chemistry students, laboratory technicians, and educators involved in teaching or learning about acid-base reactions and volumetric analysis techniques.
TheDanny
Do not understand the question.
2. My Lab Results
Topic : Volumetric analysis - Acid base
purpose : To determine the exact concentration of a mineral acid, HXO4, and to determine the relative atomic mass of the element X.
Materials : KA1 is a mineral acid, HXO4
KA2 is a solution containing 1.70g of OH- ions per dm3.
Phenolphthalein as indicator.
Procedure : Pipette 25.0cm3 of KA2 into the titration flask. Add two or three drops pf phenolphthalein indicator and titrate this solution with KA1. Record your readings in the table.
Repeat the titration as many times as you think necessary to achieve accurate results.
http://img248.imageshack.us/img248/2031/rejm9.jpg
My result up.
My problems is here the question.
a. Calculate the concentration, in mol dm-3, of solution KA2
b. Write a balanced ionic equation for the reaction between solution KA1 and the solution KA2.
c. Calculate the concentration, in mol dm-3, of mineral acid HX04 in solution KA1.
d. If the concentration of mineral acid HXO4 in solution KA2 is 20.1g dm-3, calculate the relative molecular mass of HXO4.
e. Using the answer to (d), determine the relative atomic mass of the element X.
f. Suggest and identity for element X.
Please guide me. Thx
In question (a) i tried with
mol=mass/mm
=1.7/17 = 0.1mol
mol=mv/1000
0.1=m(250)/1000
m=0.4
concentration of KA2 is 0.4moldm-3?
mol=mass/mm
=1.7/17 = 0.1mol
This is correct. Remember that the concentration was given as 1.70 g OH- per dm3 which is the same thing as 1.7 g OH- per liter or 0.1 moles/liter OH-, so this...
mol=mv/1000
0.1=m(250)/1000
m=0.4
... calculation isn't necessary.
For the rest of the problem, begin by understanding the neutralization equation.
Try to write the neutralization equation using [tex]M^+OH^-[/tex](monobasic) and [tex]HXO_4[/tex](monoprotic).
