Can a Steam Engine Be Made with Carbon Fiber Components?
The discussion revolves around the feasibility of constructing a steam engine using carbon fiber components. Participants explore various aspects of material properties, potential applications, and historical precedents in engineering.
  • Some participants question whether carbon fiber can withstand the high temperatures and pressures associated with steam engines, citing concerns about the epoxy used in carbon fiber.
  • Others suggest that if carbon fiber can match or exceed the properties of conventional materials, it could be used in steam engines.
  • A participant proposes the idea of using carbon fiber in combination with other materials, such as a steel liner for a boiler, to enhance performance.
  • There are mentions of past failures in using composite materials in aviation, particularly with fan blades, raising concerns about the reliability of carbon fiber in critical applications.
  • Some participants express skepticism about the safety of carbon fiber components in aviation, referencing historical incidents involving composite materials.
  • A suggestion is made that carbon fiber could be used in air-motors, indicating potential alternative applications.
  • Discussion includes references to innovative uses of carbon fiber in propeller blades, highlighting advancements in material technology.
Participants express a range of views on the viability of carbon fiber in steam engines, with no consensus reached. Concerns about material properties and historical failures contribute to the ongoing debate.
Limitations include uncertainties regarding the thermal and mechanical properties of carbon fiber under steam conditions, as well as the historical context of composite material failures in aviation.
miloziz
Would it be possible to build a steam engine using parts made primarily of carbon fiber? Any engine?
do you know what material is used in engine parts?? and why they are used there?? like strength, ability to withstand high temperatures of those materials..
i don't know if there are any engines made of carbon fiber part, but if carbon fiber or any other material has all the properties to match up conventional material and outbeat them, it surely can be used. that's what has been happening for so long.
The epoxy in carbon fibre probably wouldn't last long in contact with high temperature steam. You could probably make a boiler with a thin steel liner strengthened with an external carbon fibre jacket - but there isn't a huge demand for aerospace grade steam trains.
Generally CF is used where it's ligth weight justifies the cost and difficulty in making it - the only engine applications I can think of are in the front fan blades and shrouds of turbofan aircraft engines.
Maybe fused with ceramic powers the CF would take on different properties.
Have you seen this?
http://www.carbonology.com/index.asp
http://www.carbonology.com/shop.asp?PC_ID=...=76&sec_id=2116
T' foam that has been sandwiched between two layers of carbon. Incredibly light and stiff. 6mm thick and 300mm x 500mm
Note: T-Foam = Core Cell brand
http://www.noahsmarine.com/Canada/Core_Mat...micals-can.html
Core-Cell® is a new generation linear polymer foam for use as a sandwich core primarily in high quality boats. Its main properties are damage tolerance / high impact strength and good thermal resistance so that Core-Cell can be used in hulls, decks and superstructures. ......has a closed-cell structure.
I understand this carbon laminated foam material has a premium cost to it, even if it's not being shipped from England. Pretty cool though, right? Guess any hovercraft you made might have to look like a Stealth Fighter though.
http://www.carbonology.com/imglib/Picture_021_600by600.jpg
NOTE: keep in mind that carbon fiber is a conductor of electricity
Old HCA thread:
http://www.hoverclubofamerica.org/forum/index.php?showtopic=634
mgb_phys said:
The epoxy in carbon fibre probably wouldn't last long in contact with high temperature steam...
The first attempt at composite fan blades failed because of problems with rain water damage causing delamination (The first Rolls-Royce RB211 fan, c.1970)
Personally I won't ever fly in an airliner with CF fan blades - I know enough to be very afraid, but not enough to be confident the fear is irrational
You might be able to make an air-motor with a substantial number of carbon-fiber composite parts. Just a thought.
I hadn't realized they weren't CF, I know some are titanium which has it's own problems. It takes a particular kind of brilliance to invent an engien that can be ruined by rain when your office is in Derby!
http://www.geae.com/aboutgeae/presscenter/ge90/ge90_20041116.html
The GE90 engine powers Boeing 777 aircraft around the globe.
I'm sure a lot of progress has been made in the last 37 years, first attempts often fail.
thanks
I'm posting this as a late additon to this thread because I just found something of interest, enjoy.
http://www.tennantdesign.co.nz/articles/65/propulsion.html
The carbon fibre propeller blades have borrowed a technique from the mission adaptable wing technology. In that aircraft wing the orientation of the fibres allowed the wing to flex in predetermined ways to change its angle of attack. Similarly the blades of the carbon fibre propellers flex under load to change the propellers pitch.
Yeah , and then there was that air accident where all lives were lost when the Carbon fibre composite tail fin became frayed and the whole section just fell off. I think there have been incidents with helicopter blades as well. django
American Airlines Flight 587, was an Airbus 300 with a CF vertical stabiliser (rudder). It failed when the pilots used a large amount of rudder in flight to counter some wake turbulence.
The CF actually failed at several times it's design load - much better than a metal one would have done.
The actual cause was either badly trained pilots using too much rudder or the non fly-by-wire A300 allowing them to use so much rudder force in flight - depending on whose lawyers you believe.
There was unfortunately a lot of politics behind it and the CF was blamed in a lot of uninformed news stories. Calls to ban CF was quitely dropped when Boeing started to look at using CF in it's new aircraft.
I know a guy who makes helicopter tail rotor blades from carbon fiber.
9K
