Linear Approximation: Approximating \sqrt{4.1}-\sqrt{3.9}
The discussion revolves around the linear approximation of the expression \(\sqrt{4.1} - \sqrt{3.9}\), with participants exploring the setup and execution of the approximation method.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to approximate each square root separately using the linear approximation formula. Some participants affirm the steps taken but question the perceived margin of error in the approximation. Others express uncertainty about the accuracy of the approximation and the method used.
Participants are actively discussing the validity of the approximation method and the results obtained. There is a mix of affirmations regarding the steps taken and inquiries about the accuracy of the results. Some guidance is offered on maintaining consistency in defining variables and signs during the approximation process.
Participants note the challenge of approximating square roots without a calculator and the inherent difficulties in calculating values for non-perfect squares. There is also mention of potential confusion arising from the signs used in the approximation process.
antinerd
OK, I'm doing this linear approximation problem:
Approximate [tex]\sqrt{4.1} - \sqrt{3.9}[/tex]
f(a + h) ~ f(a) + hf`(a)
This is what I have done so far:
I approximated each square root separately...
4.1 = 4 + h
h = .1
f(x) = [tex]\sqrt{x}[/tex]
f`(x) = [tex]1/(2\sqrt{x}[/tex]
then I got:
[tex]\sqrt{x+h} ~ \sqrt{x} + h/(2\sqrt{x})[/tex]
so that the approximation of [tex]\sqrt{4.1}[/tex] is 2 + (.1/4)
I did the same thing for [tex]\sqrt{3.9}[/tex] and got
2 - (.1/4)
Then I just took them and subtracted
2 + (.1/4) - 2 + (.1/4)
and got .2/4 as the approximation. It seems like it's erroneous. Could someone help me out with setting up this problem if I did it wrong?
All you steps are right. Why do you think it is erroneous?
It seems to me that it is a large margin of error, I was just wondering why this is so.
Or maybe it's not too large, I'm not sure...
everything looks right to me.
check your calculator and calculate [tex]\sqrt{4.1} - \sqrt{3.9}[/tex]
it's very close to 0.2/4 = 0.05
Thanks.
It's an approximation. Without a calculator, it's not an easy task for many to calculate the square root of an arbitrary number, unless it's a "nice" number like a perfect square. In those cases, you can use this method to approximate square roots to find a number reasonably close to the right one.
So let's say I was doing something like e^(-0.1) - ln (1.1)
I can just go about doing it thus:
h = -0.1
so that:
-0.1 = 0 + h and 1.1 = 1 - h
for the first term:
f(x) = e^(x)
f`(x) = e^(x)
but then how do I go about it from there...
Could someone help me setup the problem?
I guess this would work, wouldn't it:
e^(0) - h/(e^(0))
1 - 0.1 = 0.9
Which seems reasonable...
And then for the ln(1.1) it would be
f(x) = ln(x)
f`(x) = 1/x
ln(1) - h/x
which would give me
0 - (-0.1/1)
= 0.1
That doesn't make any sense...
What'd I do wrong.
What's the problem?
Integral said:
What's the problem?
EDIT:
Should I use -0.1 for h or can i use 0.1...
When I do:
e^0 - (h / e^0)
= 1 + (0.1/1)
= 1.1
It should be 0.9 ...
I have the correct approximation for -ln(1.1) = 0.1
but I made a mistake
e^(0) - h/(e^(0))
1 - 0.1 = 0.9
Shouldn't it be 1 PLUS 0.1 to give me 1.1? Cuz h = NEGATIVE 0.1
What's wrong here?
Holy crap man, nevermind. I've been up for like 3 days straight so I'm buggin' out.
Thanks for your insight, guys :)
h = -0.1
so that:
for the first term:
f(x) = e^(x)
f`(x) = e^(x)
e^(0) - h/(e^(0))
1 - 0.1 = 0.9
Although the numbers come out right, I'm wondering why you are dividing by e^(0) instead of multiplying by e^(0)
I would advise that you approximate each term separately so that you don't get confused with the signs... Also, define h consistently...
so I'd do this:
let h = [tex]x_{actual}-x_{approximate}[/tex]
So if I'm approximating e^(-0.1) by e^0...
h = -0.1 - 0 = -0.1
And then use this exact formula where a refers to the approximate x value:
f(a + h) ~ f(a) + hf`(a) (don't switch from h to -h or anything like that... be consistent)
So: f(0 + (-0.1)) ~ f(0) + (-0.1)f'(0)
ie: e^(0 + (-0.1)) ~ e^(0) + (-0.1)(e^(0)) = 0.9
So e^(-0.1) ~ 0.9
Now approximate ln(1.1) as a separate problem, defining h again...
It is important to be consistent... worry about signs at the end...
  • · Replies 105 ·
13K
  • · Replies 18 ·
  • · Replies 21 ·
