| Thread Closed |
magnetic field around an infinitely long wire |
Share Thread | Thread Tools |
| Aug17-07, 06:54 PM | #1 |
Hello, I am trying to integrate
[tex] \int \mu_0 I (dl X r) /4 \pi r^2 [/tex] in order to get the magnetic field at a point a distance R from a wire with current I. r is the distance between the differential length and the point. I integrate over the entire wire (which becomes an angle from 0 to 2 pi). I am off by a factor of 1/pi from the correct answer of of mu_0 I/2 pi R. Is my integral or my integration wrong? |
| Aug17-07, 08:46 PM | #2 |
Recognitions:
[tex]\hat{r}[/tex] is different from [tex]\vec{r}[/tex] [tex]\hat{r}[/tex] denotes a unit vector in the direction of [tex]\vec{r}[/tex] |
| Aug18-07, 02:21 AM | #3 |
You're right. That is what I meant. I still am off by the factor of 1/pi.
I tried to change to change it to an integral with respect to an angle and got: [tex] \mu_0 I/4\pi \int_0^{2\pi} \sin \theta d\theta r/r^2 [/tex] Is that correct? |
| Aug18-07, 02:53 AM | #4 |
no why do u take the angle to be [tex]0[/tex] to [tex]2 \pi [/tex]
the angles should be [tex]\theta_{1}[/tex] to [tex]\theta_{2}[/tex] where tehse are the angles made by the wire's end points with point in case of infinite wire they turn out to be [tex]\frac{\pi}{2},\frac{\pi}{2}[/tex] or [tex]\frac{- \pi}{2},\frac{\pi}{2}[/tex] depending on how u integrate |
| Aug18-07, 03:12 AM | #5 |
Recognitions:
I get [tex] \frac{\mu_0 I}{4\pi R}\int_0^{\pi} \sin \theta d\theta [/tex] write everything in terms of R (which is constant) and [tex]\theta[/tex] and after taking all the constants outside, inside the integral you should just get [tex] sin(\theta) [/tex] The way I did was setting: x = -R/tan(theta) calculate dx (which is dl) in terms of d(theta) also set r = R/sin(theta) For some reason latex is messing up for me. |
| Aug18-07, 04:01 AM | #6 |
OK. So my integral should be [tex] \int \mu_0 I (dl X r) /4 \pi r^2 [/tex] = [tex] \int \mu_0 I sin(\theta)dl r /4 \pi r^2 [/tex] I just had a dtheta instead of a dl. I am confused about your solution. I am not sure why you introduced x. Anyway I get with your trig substitution, dx = R csc^2(x) dtheta then all the sines cancel! |
| Aug18-07, 04:04 AM | #7 |
Recognitions:
| Aug18-07, 04:06 AM | #8 |
| Aug18-07, 04:08 AM | #9 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: magnetic field around an infinitely long wire
| Force between an Infinitely Long Wire and a Square Loop | Introductory Physics Homework | 7 | ||
| Magnetic Field Vector due to Infinitely long wire | Introductory Physics Homework | 6 | ||
| Force between an Infinitely Long Wire and a Square Loop | Introductory Physics Homework | 6 | ||
| Force between an infinitely long wire and a square loop | Introductory Physics Homework | 2 | ||
| long straight wire/ magnetic field | General Physics | 2 | ||
