| Thread Closed |
Clarification on Transformers - High voltage transmission |
Share Thread | Thread Tools |
| Aug19-07, 08:28 PM | #1 |
I seem to understand transformers very well, but one aspect of stepping up voltage for transmission is confusing me. I'm sure it is a very small oversight on my part.
In an ordinary electric circuit, when the voltage is increased, keeping the load resistance the same, the amount of current increases as well. Why is it that when we step up voltage for transmission, we are not also increasing the amount of current and thus the (i^2)(R) power loss? Thanks |
| Aug19-07, 10:46 PM | #2 |
They put another transformer at the end. This changes the load impedance that the first transformer sees. Thus the current in the lines between transformers is lower.
You might note that the only positive thing this does is reduce the required size of the interconnect conductors. Transformers are not 100% efficient. |
| Aug20-07, 01:03 AM | #3 |
| Aug20-07, 05:47 PM | #4 |
Just a note. Power transmission lines are just that. Since we are transmitting power, the configuration of the lines (and hence impedence) is important. If they are not "tuned", some power can be transmitted to the moon (power loss).
| Aug20-07, 06:39 PM | #5 |
Mentor
The simple descriptions of the power distribution networks at wikipedia and HowStuffWorks aren't what I'm looking for. Anybody got some pointers to EE level descriptions? Thanks! |
| Aug21-07, 07:08 PM | #6 |
I'm no expert on power system networks and the like but I believe if you know about communication transmission lines, you know about power transmission lines also. Just bigger dimensions (since it's 60Hz), bigger transformers, etc. (oh, and much bigger hammers)
The trouble of matching the load with the transmitter is that the load keeps changing depending on how the customer uses his energy. Some customers with lots of motors, others with no load to high load in zero time. When I worked for a power company, I was involved with real-time control of generators and maintaining area control error via a SCADA system. We modeled our system at various load levels and switched to the proper B-matrix (in software) when determining which and how much each generating unit should be moved. Not only the system loads needed to be considered, but the economics involved in selecting which unit to bring up (or down). Area Control Error is sort of like an error of a pid controller. The rule was, you had to cross zero at least once a minute. ACE is the total amount of power entering(-error) or leaving(+error) your system minus your total generation (with a bias for frequency variation). To measure the ACE you need to measure the watts and vars at each tie-line substation. The system I worked with had 17 tie-line substations and 5 power plants (if I remember correctly, 13 or 14 generators). It was a fun job. edit: definition of ACE didn't originally take generation into account. |
| Aug21-07, 11:49 PM | #7 |
Mentor
That does sound like a fun job! The economics of the power generation switch-overs is yet another layer of complexity that I wasn't thinking about. Very impressive.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Clarification on Transformers - High voltage transmission
| High voltage power transmission? | Electrical Engineering | 5 | ||
| Transformers and Power Transmission Question | Introductory Physics Homework | 0 | ||
| High voltage electromachinery - the key to absurdly high power to weight ratios? | Mechanical Engineering | 12 | ||
| Voltage Drop Across Transmission Lines | Introductory Physics Homework | 2 | ||
| Need clarification on a voltage problem | Introductory Physics Homework | 19 | ||
