How to solve the integral using integration by parts?
The discussion revolves around solving an integral using integration by parts, specifically focusing on expressing the integral in terms of I(n-2). Participants are exploring the application of integration techniques within the context of trigonometric functions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the choice of functions for integration by parts, with suggestions on differentiating and integrating powers of sine. There are questions about the application of the chain rule and the correct setup for the differentiation process.
The conversation is active, with participants providing hints and corrections to each other’s approaches. Some participants are questioning their understanding of differentiation and integration, while others are clarifying the steps needed to proceed with the integration by parts method.
There are indications of confusion regarding the manipulation of integrals and the use of trigonometric identities. Participants are also navigating the implications of expressing integrals in terms of I(n-2) and the algebraic steps required to isolate variables.
t_n_p
Hi, I'm trying to solve
http://img204.imageshack.us/img204/7199/untitledke0.png
in terms of I(n-2) but I'm not exactly sure where to start/what to do :rolleyes:
You titled this "integration" by parts. Doesn't that give you a hint where to start?
Since it is much easier to differentiate a power of a function than to integrate, the choice of u= sinn(x) and dv= sin(x) seems simplest.
Since the problem says "in terms of I(n-2)" I suspect you will need to do it twice.
Dido what Halls said, with tiny corrections:
[tex]u= \sin^{n-1} x, dv = \sin x dx[/tex] is what he might have meant.
Bad mentor! Giving wrong hints, tut tut...
Hints: only perform by parts once; getting [tex]I(n)[/tex] again on the right hand side is no bad thing; remember that for trig problems you'll usually need to use trig identities at some point.
I was thinking right- my fingers hit the wrong keys!
(and it is "ditto", not "dido"!)
How would I diff u?
Use the chain rule?
Let u = (n-1) hence y=[sin(x)]^(u)
then du/dn = 1
but again, unsure how to get dy/du now..
Instead, try letting u = sin x when differentiating :)
[tex]\frac{d}{dx}\left(\sin^{n-1}(x)\right) = \left((n-2)\sin^{n-2}(x)\right) \left(\cos(x)\right)[/tex]
Btw, you can't really do integration without being able to do differentiation like the back of your hand -- more practise at that would be helpful.
I made a mistake before when doing chain rule. To prevent confusion, I will initially let f(x)=[sin(x)]^(n-1) and g'(x)=sinx
Then I use chain rule,
now I let u = sinx, hence f(x) = u^(n-1)
dy/du=(n-1)(u^(n-2))
and du/dx = cos(x)
hence dy/dx= (n-1)(sinx^(n-2))(cosx)?
genneth said:
[tex]\frac{d}{dx}\left(\sin^{n-1}(x)\right) = \left((n-2)\sin^{n-2}(x)\right) \left(-\cos(x)\right)[/tex]
Can you please explain how you got that/what steps did I do wrong above?
You got it right -- I got it wrong -- looks like I need more practice... :redface:
and du/dx = cos(x)
*in imitation of Mr. Burns on the Simpsons* Excellent..
coolio!
I sub all the relevant values into the "magical integration by parts formula", but the second part seems awfully tedious..
http://img468.imageshack.us/img468/1193/untitledyj7.png
Can (n-1) be taken out as a constant, leaving just the sin and cos terms for me to integrate by parts again?
Yes it can, but also it wants you to express cos^2 x as 1-sin^2 x, get the original integral "I" on both sides :)
ah ok!
After converting (cosx)^2 using the trig identity I get..
http://img521.imageshack.us/img521/7374/untitledfv0.png
Where to from there?
t_n_p said:
ah ok!
careful. you can't separate it like that:
[tex]\int{f(x)*g(x)dx}\ne\int{f(x)dx}*\int{g(x)dx}[/tex]
keep the [tex]sin^{n-2}x[/tex] inside the integral, and multiply it out by [tex]-1+sin^2x[/tex]
ah ok, you mean expand to give..
http://img512.imageshack.us/img512/6858/untitleddl8.png
but then what?
but then what?
Remember... your right side right now just has [tex]\int{vdu}[/tex]... but it's supposed to be [tex]uv - \int{vdu}[/tex]
To continue... remember that sums within integrals can be separated out into separate integrals (unlike products)... once that's done, you can substitute your I(n-2)... and use algebra to solve for [tex]\int{sin^n(x)dx}[/tex]
Yes it can.
Thanks for reminder, almost got carried away
After splitting and converting one of the integrals into terms of (I(n-2)), I get..
http://img205.imageshack.us/img205/7929/untitledyw3.png
But now the integral is on both sides...:confused:
edit: just changed the equation as I realized (n-1) must be multiplied by both the integrals after splitting (hence I added square brackets)..
Treat [tex]\int{sin^n(x)}dx[/tex] as an ordinary variable... you can replace it with a variable if you want (on both sides)... then solve for that variable...
Ok, after I do that, I'm confused about the expansion of the second part...
(n-1)[I(n-2)+a], where a is the integral [sin(x)]^n
with the expansion of the first term, i.e. n*[I(n-2)], how do I treat it?
just treat I(n-2) as a variable... don't do anything with it.
After expanding and taking all a's to one side and dividing by n I get...
http://img470.imageshack.us/img470/4391/untitledeq4.png
shouldn't the first term in your numerator be: [tex]-cos(x)sin^{n-1}(x)[/tex]. Other than that it looks good to me.
my bad, crappy typo.
Does that look decent for a final answer? Not much can be canceled but the "n"...
Looks fine as a final answer to me. I'd probably just write (n-1)I(n-2) instead of nI(n-2) - I(n-2).
Sweet, how would I use that solution to then solve..
http://img507.imageshack.us/img507/6310/untitledgl0.png
The 1/ is throwing me off, I'm thinking let denominator = u, but then I don't use the answer found above :confused:
  • · Replies 24 ·
  • · Replies 22 ·
