Why doesn't Taylor expansion work for integrating to infinity?
  • Context: Graduate
  • Thread starter Thread starter pivoxa15
    Integral Weird
The discussion revolves around the challenges of using Taylor expansion to evaluate integrals, specifically the integral of sin(t)/t from 0 to infinity. Participants explore the limitations of Taylor series in this context, particularly regarding convergence and the treatment of infinite series.
  • One participant notes that using Taylor expansion for integrating sin(t)/t leads to infinite terms, which seems incorrect since the integral equals pi/2.
  • Another suggests that issues may arise from uniform convergence or using an invalid Taylor expansion, emphasizing that limits and integrals cannot always be interchanged.
  • A participant humorously mentions renormalizing and summing divergent series, referencing a physicist who received recognition for such work.
  • Concerns are raised about evaluating integrals over the range 0 to infinity by simply substituting limits, with a focus on the necessity of proper limit handling.
  • Discussion includes the radius of convergence for the Maclaurin series expansion of sin(x)/x, with one participant stating it is infinite after addressing the singularity at x=0.
  • Several participants propose alternative methods for evaluating the integral, including defining a function involving an exponential decay term and differentiating under the integral sign.
  • One participant presents a derivation that leads to pi/2 as a constant but acknowledges the lack of rigor in their argument.
  • Another participant affirms the correctness of the previous derivation, providing additional clarity on the limits involved.
Participants express multiple competing views on the validity of using Taylor expansion for this integral, with no consensus reached on a definitive method or conclusion. Some agree on the need for careful treatment of limits and convergence, while others propose alternative approaches.
Limitations include unresolved mathematical steps regarding the treatment of divergent series and the conditions under which Taylor expansions can be applied to integrals over infinite ranges.
pivoxa15
Consider integrating sin(t)/t from 0 to infinity via the Taylor expansion method. If you do that then you will get infinite terms in the series which clearly is wrong as that integral equals pi/2. Can anyone tell me why using the Taylor expansion method doesn't work? It always doesn't work when integrating to infinity. But other methods like complex integral does work. Why?
Taylor expansion use to be a sure thing for me every time but now my innocence has been broken.
It's probably a uniform convergence thing - or you're using an invalid Taylor expansion - or possibly both. In general you can't interchange limits and integrals.
What does
"It always doesn't work when integrating to infinity"
mean?
Just renormalize...
If you're brave, you'll just work out how to sum divergent series. I believe some little known physicist once did that for a special and got some award out of it or something. :-p
What does
mean?
Taylor expansion expands a function in terms of polynomials. Integrate any polynomial from 0 to infinity and you get infinity hence "It always doesn't work when integrating to infinity". So a series with infinity in every term is not pleasant to say the least. In the case of sint/t, the terms are oscillating between negative and positive so the integration of the taylor polynomial on face value is 0 as you might like to subtract infinities after grouping the terms together, two by two. However infinities shouldn't be subtracted to the integral is not 0 but pi/2 when evaluated using another method.
You don't evaluate integrals over the range 0 to infinity just by putting in infinity and 0.
To the OP: What's the radius of convergence for the MacLaurin series expansion of [itex]\frac{\sin x}{x}[/itex] ?
Daniel.
what are you talking about? dimensional regularization?
Daniel.
infinity. Or for all values of x. That is after we remove the singularity at x=0.
Its got to do with putting the limit as x->infinity. You are suggesting the limit doesn't exist?
I was thinking of Feynman and QED renormalisation...
I think
[tex] \lim_{R\to\infty} \lim_{N\to\infty}\int\limits_{-R}^{R} \Big(\sum_{k=0}^{N} a_k x^k\Big) dx[/tex]
should be giving correct answer. But it is probably not possible to calculate it reasonably.
Indeed -- after taking the N->inf limit the function is what Mathematica called SinIntegral, i.e. the integral of sinc. It's a special function, so no expression in terms of "normal" functions. It's pretty much for this purpose of calculating these random integrals that complex contour integration was pursued.
there is another way to do this integral (that does not involve contour integration). define
[tex] f(x, \alpha) = \frac{\sin (x)}{x} e^{-\alpha x}[/tex]
where you recover your function when [tex]\alpha = 0[/tex]. then differentiate past the integral sign with respect to [tex]\alpha[/tex]. i'll leave the rest to you.
Good idea, but it still doesn't give the right value for the integral.
[tex]\frac{d}{d\alpha }\int_{0}^{\infty }\frac{\sin x}{x}e^{-\alpha x}dx=\int_{0}^{\infty }\left( -\left( \sin x\right) e^{-\alpha x}\right) \,dx= \frac{1}{\alpha ^{2}+1}\lim_{x\rightarrow \infty }\left( e^{-\alpha x}\cos x+\alpha e^{-\alpha x}\sin x-1\right) =-\frac{1}{\alpha ^{2}+1}[/tex]
[tex]\int_{0}^{\infty }\frac{\sin x}{x}e^{-\alpha x}dx=-\int \frac{d\alpha }{\alpha ^{2}+1}=\allowbreak -\arctan \alpha +C[/tex]
It does. The constant turns out to be pi/2, but the way I do that is not very rigorous...
Ok Here it goes: Ignoring x between -1 and 1 :( maybe someone can fill that in later for me, but anyway: The original integral is less than the negative of its derivative, since its all values in the integrand are being divided by x.
So basically it becomes [tex]\frac{1}{\alpha^2 +1} > -\arctan \alpha + C[/tex]
Take the limit as alpha approaches infinity, the LHS approaches infinity, hence
[tex]\lim_{\alpha \to \infty} -\arctan \alpha + C = 0[/tex].
Knowing that as x approaches pi/2 on the left, it goes to infinity, the limit of x as x goes to infinity for arctan x is pi/2.
Ie C = pi/2.
I know there are many holes in the argument, but it works.
that is correct. good job.
to be clear:
[tex]f(x, \alpha) = -\tan^{-1} (\alpha) + C[/tex]
[tex]\lim_{\alpha \rightarrow \infty} f(x, \alpha) = \lim_{\alpha \rightarrow \infty}[/tex] [tex]\int_0^{\infty} \frac{\sin(x)}{x} e^{-\alpha x} dx = 0[/tex]
but also
[tex]\lim_{\alpha \rightarrow \infty} f(x, \alpha) = -\tan^{-1} (\alpha) + C = -\frac{\pi}{2} + C[/tex]
[tex]\Rightarrow C = \frac{\pi}{2}[/tex]
[tex]\Rightarrow f(x, \alpha) = \frac{\pi}{2} - \tan^{-1} (\alpha)[/tex]
and
[tex]f(x, 0) = \frac{\pi}{2}[/tex]
I see it now, nice job, quetzalcoatl9 !
  • · Replies 19 ·
