Dynamics Question, Planar rigid body/ Relative velocities
The discussion centers on calculating the angular velocity of link CD in a planar rigid body problem. The user encounters discrepancies between the solution provided in a resource and their textbook, specifically regarding the angular velocity Wcd, which is stated as 15.1 rad/s versus the textbook's 4.03 rad/s. The user outlines their approach using the equations of motion, ultimately confirming that Wcd can be derived from the velocity of point B (Vb) and the relationship Vc=Vb+Vc/d, leading to the correct calculation of Wcd as 4.03 rad/s.
  • Understanding of planar rigid body dynamics
  • Familiarity with angular velocity calculations
  • Knowledge of equations of motion in mechanics
  • Proficiency in trigonometric applications in physics problems
  • Study the derivation of angular velocity in planar rigid body systems
  • Learn about the equations of motion and their applications in dynamics
  • Explore the use of trigonometry in solving mechanical problems
  • Review examples of similar rigid body dynamics problems for practice
This discussion is beneficial for students taking courses in dynamics, particularly those focusing on planar rigid body motion, as well as educators and professionals seeking to clarify angular velocity calculations in mechanical systems.
CaityAnn
http://wps.prenhall.com/wps/media/objects/3076/3149958/studypak/questions/html/Ch16/9e_16_43.html
That is the image of the problem, which includes a solution. PROBLEM- Besides being really confused on their work, the solution they give and the solution in the back of my book are both different! They said Wcd is 15.1 rad/s and my book says 4.03 rad/s, they have the same dimensions and everything.
heres what I am doing, despire the crazy solution given.. I am just trying to get some sort of method and understanding of this stuff, I am taking this course in 5 weeks so its sort of a rush to get it all in..
I want to find Angular velocity of link CD at the instant shown
Vc=Vd+Vc/d ; Vc=Vd+(Wcd x Rcd) Vd won't be moving so it goes to zero
So Vc=(WcdxRcd) ((((So I must need to solve for Vc to get Wcd))))
Va= Vb+ Va/b; Va= Vb + (Wab x Rab), Va won't be moving so it goes to zero
Vb= (Wabx Rab), I can solve for this because I am given Wab and Rab, Vb=18 in/s
Vc=Vb+Vc/d; Vc=Vb+(WcdxRcd) Vc= 8 + (WcdxRcd)
So I just need to find Vc somehow.. On the solution given they do some insane trig that I just don't get, your input is much appreciated so thanks ahead..
The answer is 4.03 rad/s and it can be found by using the equations of motion. You need to solve for the velocity of point B (Vb) which is given. Then you can use the equation Vc=Vb+Vc/d to solve for Wcd, the angular velocity of link CD. Finally, you can use the formula Wcd=Vc/Rcd to calculate the angular velocity.
11K
