How Do You Calculate Resonant Frequency and Irms in a Series RLC Circuit?
  • Thread starter Thread starter cseet
    Physics
The resonant frequency of a series RLC circuit with an inductance of 11 mH, capacitance of 2.9 µF, and resistance of 4.3 ohms is calculated to be 5.6E3 rad/s, achieved when the reactances of the inductor and capacitor are equal. The root mean square (Irms) current at resonance was initially miscalculated; the correct method involves using the total impedance (Z) of the circuit. The average current at a frequency of 7.6E3 rad/s is determined using the formula I(rms) = V(rms) / Z, where Z accounts for both resistance and reactance.
  • Understanding of series RLC circuits
  • Knowledge of resonant frequency calculations
  • Familiarity with impedance in AC circuits
  • Ability to apply Ohm's Law in AC contexts
  • Study the derivation of the resonant frequency formula for RLC circuits
  • Learn about calculating impedance in series RLC circuits
  • Explore the relationship between maximum current (Imax) and root mean square current (Irms)
  • Investigate the effects of varying frequency on circuit behavior in RLC circuits
Electrical engineering students, physics enthusiasts, and professionals working with AC circuits who need to understand resonant frequency and current calculations in series RLC circuits.
cseet
Hi all,
I've got this physics problem, I've tried solving it but do not know for sure the steps I took are correct. pls kindly advise and redirect me if I've got it wrong... thanks
A series RLC circuit with L=11mH, C=2.9uF, and R=4.3ohm is driven by a generator with a max emf of 155V and a variable frequency w (omega)
a) find the resonant frequency (units: rad/s)
answer:
R = V/I = 155/4.3 = 3.6A
XL = Vmax / Imax = 155/36 = 4.3
XL = wL
w = 4.3/11E-3 = 391rad/s
b) find Irms at resonance when w = 7.6E3 rad/s
XL = 7.6E3 * 11E-3
= 83.6 ohm
XL = V/I
I = V/XL
= 155/83.6
= 1.85A
pls direct me if I am wrong... appreciate it... I've learned more in this forum than in school...
thanks
cseet
Hi all,
I reckon b) 1.85A is the Imax therefore it should be 1.85 / square root of 2 = 1.31A?
pls advise
cseet
Resonant frequency is achieved when the reactances of the capacitor and induction coil are equal. The resistance of the resistor in this case doesn't matter, and neither do the maximum EMF or current.
[tex]X_L = X_C[/tex]
[tex]\omega L = \frac{1}{\omega C}[/tex]
[tex]\omega ^2 = \frac{1}{LC}[/tex]
I get a value of 5.6E3 rad/s.
As for the second part, I don't quite understand why it says "find Irms at resonance when w = 7.6E3 rad/s", because, as I just demonstrated, the circuit is only at resonance for ω = 5.6E3 rad/s. But, I will show you how to find I(rms) regardless, since you went about it the wrong way (you found the current through the coil alone, not the circuit as a whole). The overall 'resistance' of the circuit is Z, which is:
[tex]Z^2 = R^2 + (X_L - X_C)^2[/tex]
So the average current is:
[tex]I_{rms} = \frac{V_{rms}}{Z} = \frac{\frac{V_{max}}{\sqrt{2}}}{\sqrt{R^2 + (X_L - X_C)^2}}[/tex]
Where XL and XC both depend on \omega;.
  • · Replies 40 ·
13K
