| Thread Closed |
"Sea" of electrons in metals |
Share Thread |
| Aug27-07, 05:42 PM | #1 |
Is it a "floating" sea of electrons in metals? meaning they are not restricted to a spot relative to the atoms, but they just "float" around as long as it's in the metal, and the charge is almost perfectly level throughout the metal. (I doubt it would be absolutly entropicly level)
Arn't electrons pulled by gravity? So a metal pole being held up vertically would stay there because the atoms are "locked" into place with relation to eachother, but the floating electrons are not, so would they fall to the bottom edge of the pole? This effect might be very very small because the entropy of the charge forces would be much stronger then gravity. |
| Aug27-07, 07:52 PM | #2 |
To your first question, yes, I think they do just 'float' around in the metal.
As for your second question, I'm pretty sure that gravity is so insignificant as to be meaningless on the atomic scale. The other forces (electromagnetic, strong nuclear, weak nuclear) are many orders of magnitude stronger. So no, the electrons will not 'fall' to the bottom of the pole. If they did, you'd get shocked every time you touched a pole ;) |
| Aug27-07, 08:53 PM | #3 |
Recognitions:
energies of free electrons in the fermi sea versus typical gravitational potential energies. Thus we are comparing a number on the order of 10 eV (typical fermi energy) to the number [tex] m_e g h [/tex] where h is the height. In order for the gravitational potential energy to be comparable one would need [tex] h \approx 10000 \textrm{meters} [/tex] If, on the other hand, we were talking about a free gas of, say, air molecules instead of electrons, then we would compare to kT (much less than typical E_f usually) and find a height of much less. That's why one does have to take gravitational potential energy into account in the thermodynamics of air in the atmosphere, for example... but for the case of electrons in a rod one can safely ignore gravity except in the case of a very very very long rod. Cheers. |
| Aug27-07, 09:08 PM | #4 |
"Sea" of electrons in metalsSee also: Bloch states Nearly free electron approximation Tight binding model |
| Aug28-07, 07:56 PM | #5 |
Thanks. I wounder if spinning a star shaped (or anything that comes to points on the outer radious) piece of metal, at extremely fast rmp would cause a voltage difference from the centre of the spin to the outer edge of the spin. Or are the other forces that keep the electrons still far too stronge to overcome? Well ofcourse there would be some voltage, though maybe unmeasureably small.
| Aug29-07, 02:10 AM | #6 |
Recognitions:
that's an interesting question, but again I think that the frequency would have to be quite high indeed to observe any effect.
| Aug29-07, 02:57 AM | #7 |
I'd imagine that would take tangential velocities comparable to the Fermi velocity (~106 m/s) before you notice much change in the charge density.
| Thread Closed |
Similar discussions for: "Sea" of electrons in metals
| Alpha Decay "extra" electrons | High Energy, Nuclear, Particle Physics | 12 | ||
| Conductivity of a semiconductor charged with "externally added" electrons | Atomic, Solid State, Comp. Physics | 3 | ||
| Why aren't electrons considered "black holes"? | Special & General Relativity | 18 | ||
| "Massless" electrons behave relativistically | Atomic, Solid State, Comp. Physics | 6 | ||
