How to prove Fermat's Last Theorem mathematically
  • Level: Graduate
  • Thread starter ron_jay
    Theorem
52 replies · 16K views · last reply
ron_jay
We all know of this theorem which was finally proved in the 1960's. It says that we cannot find any real integral solution for n>2 when an integer is expressed to a power of 'n' and is equal to the sum of two numbers which individually are raised to the power 'n'.
x^n=a^n+b^n
Well for n=2, we are familiar with the pythagorean(3,4,5 etc.) combinations, but there is indeed is no solution when n>2...check it out.
I recently ran a program to find this solution, but couldn't find for n=3,4,5... This certainly validates the theorem but how do we prove it mathematically?
Either try all infinite 'n' - might take a while (actually only need to test all the infinite number of prime n's)
or learn an awful lot of seriously complicated number theory about elliptic curves and some conjecture that I can't even spell as Andrew Wiles did. There isn't a proof understandable by mere mortals.
Yes, that's a mistake, it was done so in the 90's but that's apart from the point...
There is a good book by Simon Singh, but since it is pretty impossible to even outline the numerical techniques to someone without grad school maths it mainly concentrates on the stories of the people involved.
It would be interesting to know what Fermat's original proof was and where he went wrong!
There was no original proof. After he wrote his comment in the margin of a book, he gave completely different proofs for n= 3 and n= 4. He wouldn't have done that if he had a proof for all n.
What happened to Fermat is what happens to mathematicians all the time- he saw a way of extending result he already had and wrote that "marginal" comment. Later he realized it didn't extend as he thought.
Also known as the Taniyama–Shimura conjecture. Don't even bother starting unless you already know what elliptic curves and modular functions have to do with each other. (I don't. Not a clue.)
I wouldn't say it is "also known as". Yes, Wiles proved the Taniyama-Shimura conjecture. It has already been proven that Fermat's last theorem was true if and only if theTaniyama-Shimura conjecture was true.
The German mathematician Frey announced that he believes that Fermat's equation, if false, will imply that the Taniyami-Shimura Conjeture to be false. This became known as the Eplison Conjecture. Soon the mathematician Kenneth Ribet actually prove this idea in detail. Wiles immediately realized that all he needs to do know if prove the Taniyami-Shimura Conjecture.
In the old days, Fermat's problem was attacked by Kummer Ideal Complex numbers. But this does not work succesfully. There is a book (I forgot the name) which teaches algebraic number theory while simultaneously working with Fermat's equation in a classical approach.
How did you "run a program" to check for all n= 3, 4, 5?
HallsofIvy said:
I wouldn't say it is "also known as". Yes, Wiles proved the Taniyama-Shimura conjecture. It has already been proven that Fermat's last theorem was true if and only if the Taniyama-Shimura conjecture was true.
I thought Taniyama-Shimura was stronger than Fermat's last theorem -- that Wiles proved special case of T-S first, enough to prove Fermat's last theorem, and later (with several others) proved the whole Taniyama-Shimura conjecture. Am I confusing this with something else?
It was bit of an accident that I stumbled upon Fermat's Last Theorem. I was originally coding a program to find the smallest number, which when squared, can be expressed as the sum of two different sets of individually squared numbers, which is:
65 = 1^2+8^2 = 4^2+7^2
in terms of three three numbers, you have:
325 = 1^2+18^2 = 10^2+15^2 = 6^2+17^2
in terms of four numbers, you have:
1105 = 23^2+24^2 = 4^2+33^2 = 9^2+32^2 = 12^2+31^2
This list goes on...but what I tried to do next is replace the power of n=2 with n=3 or greater integral values. What I encountered is that the program kept looping till infinity i.e. the program never terminated for the first set of two numbers cubed individually(a^3+b^n=c^n);this led me to doubt the program. I checked the program but found no errors. So I concluded that there was no solution for a power greater than 2. I incidentally also came across Fermat's last theorem.So my conclusion was indeed justified.
Well, here is a program in c++ for reference:
Code:
#include <iostream.h>
#include <conio.h>
#include <math.h>
int main()
	 long n=1,i,j,flag,s,k;  //initializing
	 long p=3;               //replace 'p' to check for any other power
	 while(1)                //loop till infinity
		flag=0;k=pow(n,p);
		for(i=1;pow(i,p)<k;i++)         //looping first number
			for(j=i+1;pow(i,p)+pow(j,p)<=k;j++) //looping second number
			  s=pow(i,p)+pow(j,p);
			  if(s==k){flag++;}
			  if(flag==2){break;}           //break out of loop if found
			if(flag==2){break;}
	  if(flag==2){cout<<n;break;}  //print number if found and the program terminates
	  n++;
return 0;
Replace 'p' for power of the expression, and you will find that for p=2, answer is 25 which rightly is the smallest pythagorean triplet; but for n>2 and n having an integral value, the program doesn't terminate i.e there is no solution.
Have you it for an infinite time yet?
To prove all odd numbers greater than 2 are prime numbers :
Mathematician: 3 is prime number, 5 is prime number, 7 is prime number, by induction, all odd numbers greater than 2 are prime numbers
Physicist: 3 is prime number, 5 is prime number, 7 is prime number, 9 is experiment error, 11 is prime number,...
Engineer : 3 is prime number, 5 is prime number, 7 is prime number, 9 is prime number, 11 is prime number,...
Computer Programmer: 3 is prime number, 5 is prime number, 7 is prime number, 7 is prime number, 7 is prime number,...
Statistician: Let us try some random numbers: 17 is prime number, 23 is prime number, 11 is prime number,...
ha...Alrighty. Agreed that the program will not run for an infinite time but if there was a solution to it, the program would have given it in a relatively short period of time.Wouldn't it? So you could conjecture that the equation is unlikely to have a solution.
No. You cannot say that. The behaviour for a small, finite time, is no indicator of the over all behaviour.
I don't mean to say that it is universally true that for a small behaviour, the overall behaviour is truly indicated. It was only in my case that the unavailability of the solution by the program for a small time led me to faintly suspect that there might be something peculiar about the solution. It was a thought pertaining only to the situation and was not a generalisation of sorts for all other mathematical concepts.
So what exactly is the Taniyama-Shimura conjecture?
See http://www.math.hmc.edu/funfacts/ffiles/20009.5.shtml
If you're generalization to 'all integers' is based merely on some searhc not terminating, rather than examining the reason why it does not terminate quickly, then you've clearly done something rash.
Sure, you can conjecture that -- and you did, and you were right. There are lots of examples of problems with large smallest counterexamples, though, so matt took issue with your guess. Eh.
No. It's not rash at all.The search did not terminate for a reason, did it? And it is because according to the theorem there is no solution to an integral power above 2. So, the reason was examined and that is how I came across this ingenious theorem.
One way to go about solving it would be that a power of 4 for example can be expressed in terms of 2*2 or algebraically, 'p=mn'
(a^m)^n + (b^m)^n = (c^n)^n
Perhaps we could somehow use this identity(though I don't know how).
Yes, as i said you don't have to check all infinite 'n' just the infinite number of prime 'n'.
Since any non-prime 'n' can be expressed as the sum of 2 prime, another tricky one to prove by the way!
yes it is, since you had no explanation of why it did not terminate,
what reason would that be? That you knew something about certain modular forms? Or because you didn't have a powerful enough computer, or didn't let your program run for long enough?
that is complete BS. Example? OK, find an integer solution of
42323245673565835789467946805234545765831346256725764x^6+ 1356468356835783234623456724689514123412354513487654794679745x^5+264653246432576548769256341452325341654364575468798569869867357846986596234534x^2+x+1
or show none exists. Please, start your computer program now...
Let's say your program stops at 9,223,372,036,854,775,807 (if you're using a signed long variable in java), for n = 3. How do you know the solution isn't at 9,223,372,036,854,775,808?
On the other hand, if you can prove that your program will not terminate, then you can conclude that there are no solutions.
Unfortunately the halting problem is even less solved than fermat's last theorem!
There was something called the Euler Conjeture: It takes n nth powers to make an nth power. This was largely accepted until it was shown--by virtue of a zero for the fifth left term, I have been told, that 27^5 + 84^5 +110^5 + 133^5 = 144^5. A larger case discovered in 1967 as well is: 85282^5 + 28969^5 +3183^5 + 55^5 = 85359^5. (It is interesting to note that 85359^5 = 4.53..x10^24, large enough to suite me.)
Also I am sure people know just as 3^2+4^2= 5^2, we have 3^3+4^3+5^3 = 6^3. Well it is sort of interesting that 4^5 + 5^5 +6^5 +7^5 +11^5 = 12^5.
He isn't asked to prove that his program will tell whether any other program will terminate. I'm sure there are proofs that uses the fact that an algorithm does not terminate. I can't think of anything non-trivial for the moment, but I remember seeing something like that in many proofs in graph theory.
Erroneous
matt grime said:
yes it is, since you had no explanation of why it did not terminate,what reason would that be? That you knew something about certain modular forms? Or because you didn't have a powerful enough computer, or didn't let your program run for long enough? that is complete BS. Example? OK, find an integer solution of
What you have said is perfectly correct, but the main purpose of my question has been defeated and it is not BS.I did not positively conclude that the anomaly of the program not terminating is caused due to Fermat's Last Theorem at first thought. It was only after learning about the theorem and then ruminating that perhaps, yes, the evidence that the equation does not have a solution as said by Fermat and then proved by Andrew Wiles may have an answer to to it not terminating, even if it is for a short period of time.Yes, I had beforehand knowledge that there may not be a solution to the equation and hence for any great value(9,223,372,036,854,775,807), the program will not return an answer. Unfortunately, lot of misunderstanding has crept in.The program does not prove or validate Fermat's Last theorem(that's were I think we are going wrong),but is in fact a consequence of it.
From post 1 by ron_jay:
from post 28 by ron_jay:
the program does not prove or validate Fermat's Last theorem(that's were I think we are going wrong),but is in fact a consequence of it.
That's where we are going wrong?
Correct, that if you can prove that the program does not terminate, the theorem will be proved just like the Taniyama-Shimura Conjecture was a precedent to the proof of Fermat's Last theorem.Right, we don't know whether the last possible long digit available to the program is the solution or not and it could be, but all I am doing is laying down a conjecture that if the program had not terminated and we knew that it hadn't in some way, we would arrive at a conclusion and you have rightly voiced my own opinion in every way.
Let's say I name it the "NON-Terminating Program Conjecture".:smile:
