Charged Aluminum Spheres: Calculating Electrons and Attractive Force
The discussion revolves around a physics problem involving two aluminum spheres, focusing on calculating the number of electrons in each sphere and determining the number of electrons that need to be transferred to create a specified attractive force between them. The subject area includes electrostatics and Coulomb's Law.
  • Mixed
  • Participants discuss the calculation of the number of electrons in aluminum spheres and the application of Coulomb's Law to find the charge needed for a specific force. There are varying results for the number of electrons calculated in part A, leading to questions about the methodology used.
Some participants are exploring different approaches to calculating the number of electrons, with discrepancies noted in their results. There is an ongoing examination of the calculations for part B, with suggestions to clarify the relationship between protons and electrons in the context of the problem.
Participants are working under the constraints of the problem as presented in a homework context, with some expressing confusion over the application of atomic properties and the calculations involved. There is an acknowledgment of potential misunderstandings regarding the number of electrons versus the number of atoms in aluminum.
Gaupp
I'm having difficulty with a problem on MasteringPhysics (such wonderful software...) and as a last resort I'm posting on here. This is, I'm sure, a really simple problem but I'm getting no kind of feedback from MP and there isn't an example problem like this in the book.
Two aluminum spheres of mass .025 kg are separated by 80 centimeters.
A) How many electrons does each sphere contain?
B)How many electrons would have to be removed from one sphere and added to the other to cause an attractive force between the spheres of magnitude 1.00 x 10^4 (roughly one ton)? Assume that the spheres may be treated as point charges.
C)What fraction of all the electrons in one of the spheres does this represent?
F=K*q1*q2/(r^2)
q=e*(#protons-#electrons)
A) I found Part A to be 7.25 x 10^24 electrons.
B) This is where I'm stuck.
If you were to remove electrons from one sphere and put them on the other I understand that their charges are to be equal but opposite, as in q1 = -q2. So using Coloumb's Law (F=K*q1*q2/(r^2)) I've set the Force to 1*10^4, divided that by K=9*10^9.
10000/(9*10^9) = q1*q2/(.8^2)
Then multiplying that by .8^2, I have just the charges on the other side of the equation. Since the charges in the formula are absolute value I can set q1=q2 and have q1^2. Taking the square root of the entire thing I have:
q=8.4327*10^-4.
So now I can use the formula q=e(#protons-#electrons). So:
8.4237*10^-4 = 1.6*10^-19(7.25*10^24-#electrons). Solving from this I get 7.249*10^24 electrons as my final answer.
However, MP says I'm wrong but there isn't any feedback as to where I went wrong, and it seems straightforward enough to me that no matter how I rework it I get the same thing every time.
Can anyone help me out here?
C) Can't do this one until B is done.
Any help is greatly appreciated.
how you did 'a'?
I am getting something different [5.58E20]
rootX said:
how you did 'a'?
Code:
.025 kg x [U]1000g[/U] x [U]1mol[/U] x [U]6.023*10^23 atoms in a mol[/U] x [U]13 electrons[/U] = #electrons
           1kg  26.982g               1 mol             1 atom Al
oops, I forgot units...
but do you get 7. something when you do this cal. on calculator?
my cal's giving me 5.something
and you getting
and you getting
How much does each ball weigh in your problem? It could be different, especially if you're doing this in MP.
and you getting
multiply by the atomic number of aluminimum (ie number of protons in an atom which equals the number of electrons in an atom)
I'm confused by what you did in part B... the charge you calculated looks correct... you just need to divide by 1.6*10^-19 to get the number of electrons.
You have to? I think maybe not. (We never did that)
oo..O you don't know that part A is correct try without multiplying by #13, hopefully, you may get the right answer
Gaupp did... he didn't write it out..
Remember you need the number of electrons... not the number of atoms...
So number of atoms * (number of electrons/atom) gives the answer... I get the same answer as Gaupp.
So number of atoms * (number of electrons/atom) gives the answer... I get the same answer as the Gaupp.
ooo.. yea you are right.. that gives the # of atoms, not the # of electrons
Ok I see now. The difference between the #protons and the #electrons would be the number of electrons lost or gained. I kept solving for just the number of electrons, by moving around the #protons in the equation. DOH!
Thanks for the help there learningphysics.
