Number 9 multiplication tricks
  • Context: High School
  • Thread starter Thread starter Rick890
The discussion revolves around the properties of multiplication involving the number 9, particularly focusing on the sum of the digits of the resulting product. Participants explore whether the sum of the digits of products of 9 with positive integers always equals 9, and they examine related concepts such as modular arithmetic and the technique known as "casting out nines."
  • Some participants propose that multiplying 9 by a positive integer results in a product whose digits sum to 9, but this claim is questioned with examples showing that the sum can be a multiple of 9 without equaling 9.
  • One participant explains the concept of "casting out nines," noting that it is based on modular arithmetic where 10 is congruent to 1 modulo 9, allowing for simplifications in calculations.
  • Another participant elaborates on how modular arithmetic properties can be applied to verify calculations, emphasizing that the sum of the digits can be calculated modulo 9.
  • Some participants discuss the historical use of casting out nines in bookkeeping as a method for error checking, acknowledging its limitations.
  • There is mention of similar properties in other bases, such as base 8 and base 16, suggesting a broader mathematical principle at play.
  • One participant reflects on the educational aspect of these multiplication tricks, expressing a desire for earlier exposure to such techniques in school.
Participants express differing views on whether the sum of the digits of products of 9 always equals 9, with some agreeing that it can be a multiple of 9 while others question the generality of the claim. The discussion includes both supportive and critical perspectives on the application of casting out nines.
Some assumptions about the nature of the numbers involved (e.g., positive integers) are present, and there are unresolved questions regarding the completeness of the proof for the digit sum property. Limitations of the casting out nines method are acknowledged, particularly its inability to catch certain types of errors.
This discussion may be of interest to those studying modular arithmetic, educators looking for teaching techniques, or individuals interested in historical methods of error checking in calculations.
Rick890
It seems that if the number 9 is multiplied by a number, the resulting digits of that number will sum to 9. Does this always hold true? Is there a simple proof for this, or at least a proof up to some finite number?
Mathematics news on Phys.org
I assume that by a "number" you are referring to a positive integer.
9x11 = 99
9+9 = 18 != 9 (although 1+8 = 9)
It's easy to prove that sum of the digits is always an integral multiple of 9, though.
It's called "Casting out Nines." The fact is that 10 congruent to 1, Modulo 9, (you might have to look up modulo) and thus 10^n==1 Mod 9 for n a positive integer. So that:
[tex]\sum a_i10^n \equiv \sum a_i[/tex] Modulo 9.
This fact was often used by bookkeepers in the old days as a check on figures. After calculating the answer, they would go through the problem again "casting out nines," to get a check.
For example: 125x275 = 34375== 4 Mod 9. and 125==8 Mod 9, 275 ==5 Mod 9. So that 125 x 275 ==8x5=40==4 Mod 9.
This is a consequence of the behavior of modular arithmetic, plus the fact that 10 = 1 (mod 9).
Your multiple of 9, as any other number, can be expressed as its digits multiplied by powers of 10; say, 1845 is 1.10^3 + 8.10^2 + 4.10 + 5. Now, being a multiple of 9 means that its remainder when divided by 9 is exactly zero. So you would write, 1845 = 0 (mod 9).
Arithmetic modulo some number n (in our case, modulo 9) has this useful properties:
If a = a' (mod n) and b = b' (mod n), the following are true:
  • a + b = a' + b' (mod n)
  • ab = a'b' (mod n)
  • a^i = a'^i (mod n), for any integer i
So any expression you can write using sums, products or powers to some integer, will produce the same result whether
  • you calculate the whole expression first, and then finally take the remainder modulo n, or
  • you take the remainders modulo n of your numbers, and do the operation on the remainders, taking the modulo n after each operation.
For the example number above, you can do all operations "mod 9", taking notice that 10 = 1 (mod 9). Then you have:
1845
= 1.10^3 + 8.10^2 + 4.10 + 5
= 1.1^3 + 8.1^2 + 4.1 + 5
= 1 + 8 + 4 + 5 (mod 9)​
Another statement of what has been explained Robort Ihnot and Dodo is that whenever you add nine it corresponds to adding ten and removing one. In other words, you move digit values from the tens to the ones, but you do not change their sum.
Can you run through this a little slower? This seems like an incredibly powerful tool for checking numbers (for those of us old fools who still try to do it without computers).
[ EDIT ] Never mind, a quick Wiki did the trick. I've got to try that next time I have several large numbers!
MAN I wish I'd known that trick in grade school and high school! Many of my tests and assignments were lower than expected because of no expedient way of cross-checking.
The biggest use of "casting out nines" was in Accounting, where it might be discussed. Of course, it is not a fool-proof test, but serves as a quick check. A common error, so I was told, is for the writer to reverse digits, such that 23 was put down as 32. Of course casting out nines will not help with that error.
I have noticed that few students today even understand that to multiply 9 by a single digit number, from 2-9, you subtract 1 and add what it takes to make nine for the second digit. Thus 9x5 = 45. This is such a simple thing if you are learning the multiplication tables.
In base 8, 7 has the same property as 9 does in base 10. Similar with 0xF in base 16.
Hmmm...I think this sentence could have been better constructed, wot?
