Transforming Differential Equations: Laplace and Algebra
The discussion revolves around solving a differential equation of the form y'' + 2y' + 2y = sin(at) using Laplace transforms. The original poster expresses difficulty in manipulating the algebraic expressions resulting from the transformation and is required to find specific coefficients in a partial fraction decomposition.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the use of partial fractions to decompose the transformed equation. Some suggest checking the setup of the partial fractions and the form of the numerators. Others question whether the original poster is allowed to use alternative methods or tools like Matlab for assistance.
There is ongoing exploration of different approaches to find the coefficients A, B, C, and D in the partial fraction decomposition. Some participants have offered suggestions for specific values of s to simplify the problem, while others have pointed out potential oversights in the original poster's algebraic manipulations. The discussion remains active with various interpretations being considered.
The original poster is constrained to manual calculations without the use of computational tools, as specified in the homework requirements. There is also a mention of the problem being part of a basic course, which may influence the complexity of the expected solution.
Yann
I must find the solution of a differential equation, but I'm stuck with a problem of algebra;
The problem is
[tex] y''+2y'+2y = sin(at)[/tex]
With y(0) = y(0)' = 0
[tex] s^2L[y]+2sL[y]+2L[y] = \frac{a}{s^2+a^2}[/tex]
[tex] L[y](s^2+2s+2) = \frac{a}{s^2+a^2}[/tex]
[tex] L[y] = \frac{a}{(s^2+2s+2)(s^2+a^2)}[/tex]
I transform it;
[tex] L[y] = \frac{a}{([s+1]^2+1)(s^2+a^2)}[/tex]
[tex] \frac{a}{([s+1]^2+1)(s^2+a^2)} = \frac{A(s+1)+B}{[s+1]^2+1}+\frac{C}{s^2+a^2}[/tex]
[tex] a = [A(s+1)+B](s^2+a^2) + C[(s+1)^2+1][/tex]
I just don't have a clue how to find A, B and C from here...
You might want to check your partial fractions again, though you might have just made a typo. Are you allowed to use Matlab or Mathematica to crunch through your partials (that is what I would do)? Also, are you not allowed to simply use superposition of the homogeneous and particular solution (you have a linear system with a very well known answer), do you have to use Laplace transforms?
Thx for the answer..
I really have to use Laplace transformes, it's in the question, and no, I tcan't use MatLab or any other programs, I need to do it manually.
Okay, well this will require a lot of pointless brute force. Alright, so the right hand side is a function of s, which is equal to a for all values of s. This also means that it must be true for particular values of s, and you can choose certain values of s to find your variables, so what if you conveniently make s = -1? How about s = ia (where i is the imaginary unit)? So far you should have B and C. What about A?
There must be some other way, it's only a basic course, after all. Perhaps I'm making a mistake in the Laplace transforms...
Nobody has an idea ?
You haven't considered that the numerator of the second fraction may be of the form Cs + D...
I'd write the numerator of the first fraction on the right side as As + B. And the second one as Cs +D. Then do what you did before... bring it all under the same denominator... then multiply out the numerator on the right side, and gather terms together... finally equate the left side with the right side... you're equating coefficients of s^a...
So all the coefficients on the right side should be 0 except for the constant term... so immediately you'll get C = -A using the s^3 term... continue with all the coefficients...
I didn't check your Laplace transforms, and I missed the s^2 in the second one, but given that you do all that right, the method I gave you will work. You can also use the "cover up" method, which works on the same principle.
I tried, but I know the solution (because of Maple) is;
[tex] y(t) = \frac{e^{-t}sin(t)a^3}{4+a^4}+\frac{2e^{-t}cos(t)a}{4+a^4}+\frac{2\sin(at)-2a\cos(at)-a^2\sin(at)}{4+a^4}[/tex]
And I'm not getting there.
In fact I think we have to go with;
[tex] \frac{a}{([s+1]^2+1)(s^2+a^2)} = \frac{A(s+1)+B}{[s+1]^2+1}+\frac{Cs+D+E}{s^2+a^2}[/tex]
  • · Replies 18 ·
