What is the relationship between wavepacket uncertainty and probability density?
The discussion focuses on the relationship between wavepacket uncertainty and probability density in quantum mechanics, specifically regarding the formula for the uncertainty in position of electrons localized to ±1 μm over time t. The key equation presented for the probability density is |\Psi(z,t)|^2 = \frac{\pi.(\Delta k^{2})}{\left(1+\frac{\hbar^{2}(\Delta k^{4}t^{2})}{4m^{2}}\right)^{1/2}}.exp\left(\frac{(\Delta k^{2})(z-vt)^{2}}{2\left(1+\frac{\hbar^{2}(\Delta k^{4}t^{2})}{4m^{2}}\right)}\right). The discussion highlights confusion regarding the introduction of the square root in the denominator and the justification for the claim that \Delta p\Delta z \approx \sqrt{2}. Understanding these concepts is crucial for accurately calculating wavepacket behavior.
  • Quantum mechanics fundamentals
  • Understanding of wavepacket dynamics
  • Familiarity with the Heisenberg uncertainty principle
  • Knowledge of Gaussian functions and their properties
  • Study the derivation of the Heisenberg uncertainty principle in detail
  • Learn about wavepacket evolution in quantum mechanics
  • Explore the mathematical properties of Gaussian functions
  • Investigate the role of \Delta k in wavepacket uncertainty calculations
Students and researchers in quantum mechanics, physicists analyzing wavepacket behavior, and anyone interested in the mathematical foundations of probability density in quantum systems.
T-7
Hi,
I'm puzzled by a couple of formulae in the answer sheet to a problem set I'm working on.
To calc. the new uncertainty in the position of a group of electrons, initially localised to [tex]\pm1\mum[/tex], after time t, it uses the factor:
[tex]\left(1+\frac{\hbar^{2}(\Delta k^{4}t^{2})}{4m^{2}}\right)^{1/2}[/tex]
The equation I would use for the probability density of this wave is
[tex] \left|\Psi(z,t)\right|^{2} = \frac{\pi.(\Delta k^{2})}{\left(1+\frac{\hbar^{2}(\Delta k^{4}t^{2})}{4m^{2}}\right)^{1/2}}.exp\left(\frac{(\Delta k^{2})(z-vt)^{2}}{2\left(1+\frac{\hbar^{2}(\Delta k^{4}t^{2})}{4m^{2}}\right)}\right)[/tex]
The denominator of the exp. component describes the increasing width of the wave packet (whereas [tex]\left(1+\frac{\hbar^{2}(\Delta k^{4}t^{2})}{4m^{2}}\right)^{1/2}[/tex] describes the decreasing peak height). I am puzzled by the square root sign they've introduced. Shouldn't they have simply applied it without?
Clearly, one needs to calc. [tex]\Delta k[/tex] to determine the new uncertainty in position, but I'm also puzzled by the claim that [tex]\Delta p\Delta z \approx \sqrt{2}[/tex] (nowhere justified). How do they figure that one?
Cheers!
The uncertainty of a gaussian is usually taken to be its std. dev. The denominator in the exponent is usually [tex]2\sigma^2[/tex] where sigma is the S.D.
Thank you. :smile:
  • · Replies 0 ·
  • · Replies 0 ·
