Thread Closed
Zero and Infinity
Share Thread Thread Tools
Aug30-07, 01:21 PM   #1
Zero and Infinity
We know that anything divided by zero is 'undefined' or equal to infinity. Is it not possible to define in anyway such indeterminate quantities? The concept of zero basically refers to 'nothingness' or 'void', but that indeed has utmost importance in writing numbers. If you consider a general number line, we can position the zero at any given reference point and the negative and the positive integers follow suit either way of the line till infinity. Is there actually any absolute zero quantity and does infinity ever tend toward finite grounds?
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Aug30-07, 02:49 PM   #2
Sure, as x approaches 0, sin x approaches 0 while sin x / x approaches 1.
sin x / (x*x) approaches is "undefined" (i.e. it approaches plus or minus infinity) as real x approaches 0.
So, 1 / (x*x) at x = 0 is a much larger infinity than 1/x at x = 0. The former has a double pole there while the latter has a simple pole. The magnitude of the former infinity is essentialy the square of the latter, within some complex number factor.
You can also say that d/dx (x*x) = ((x+dx)*(x+dx)-x*x)/dx = 2x + dx where dx is an infinitesimal quantity equal to 1 / infinity. Or you can round it off to d/dx (x*x) = 2x.
Usually intuition suffices, but if you want to do this stuff rigorously, look into non-standard mathematics where
one can use the compactness theorem to shoehorn an infinitesimal quantity into the real number system.
Yes, it's denoted by 0 and its the quantity that when multiplied by any finite quantity yields 0. If you are dealing with times/positions/temperatures where you can choose to call some arbitrary measurement "0" then you've left the realm of pure numbers.
Yes, the sequence 1/5, 1/4, 1/3, 1/2, 1/1, 1/0, 1/-1, 1/-2, 1/-3, etc. shows how a positive quantity can grow, become infinite and then suddenly become negative. In this case plus/minus infinity appears between the positive and negative numbers. Other interesting examples of infinity becoming finite include zeta(-1) = 1 + 2 + 3 + 4 + 5 + ... = -1/12 and also exp(-zeta'(0)) = 1 * 2 * 3 * 4 * 5 * ... = sqrt(2 * pi)
Aug30-07, 04:54 PM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by ron_jay View Post
This statement is not correct in the sense that you meant it. If something is undefined, then anything involving it is undefined. (In ordinary arithmetic) the statement "1/0=infinity" is undefined -- it is not true, nor is it false: it is nonsense. In ordinary arithmetic, there is nothing called "infinity", so that's another reason that assertion is nonsense.
On the projective real line, there is something called "infinity". And in this context, 1/0 is not undefined: it is defined, and equal to infinity. Just to emphasize the point, that division symbol has a different meaning than it does in ordinary arithmetic. (Though the two usually agree)
On the extended real line, there is something called "positive infinity" and something called "negative infinity". In this context, 1/0 is undefined.
In the hyperreals, there is nothing called "infinity". But there are numbers that are infinite; by definition, x is infinite if and only if |x|>n for every ordinary natural number n. In the hyperreals, 1/0 is not defined. But if e is an infinitessimal number, then 1/e is an infinite number.
No it doesn't. In (usual) arithmetic, the concept of zero is something that satisfies the identities:
0+x = x+0 = 0,
0x = x0 = 0.
It might be the case that in certain applications of arithmetic, there is a notion of nothingness, or of a void, but those notions are not a part of arithmetic.
Aug30-07, 06:59 PM   #4
Zero and Infinity
infact, one of the marks of distiction with regard to the mathematics of ancient civilization is whether or not the concept of zero was developed. in other words did they understand the notion of:
12304 = 1*10,000 + 2*1,000 + 3*100 + 0*10 + 4*1
without zero you cannot have a positional number system, which is a major disadvantage (try multiplying in greek numerials, for instance).
Aug30-07, 07:48 PM   #5
This should be moved to philosophy forum.
Aug31-07, 06:07 AM   #6
Recognitions:
Any time anyone says something so vague as to be meaningless, it should be moved to the philosophy forum?
Aug31-07, 07:24 AM   #7
Pure maths shouldn't be confused with philosophy.Those who do (no insinuation) are philosophers themselves.
Aug31-07, 07:34 AM   #8
What about the people who philosophize about the difference between pure math and philosophy?
Aug31-07, 07:35 AM   #9
Recognitions:
Homework Helper Homework Help
From post 1:
Anyone who confuses that statement with pure maths is not a pure mathematician.
Aug31-07, 09:38 AM   #10
Quote by Dragonfall View Post
Quote by matt grime View Post
From post 1:
Ok. Lets have a definition of 'philosophy', without which all relative arguments are bound to crop up.There is a subtle difference between 'philosophy' and 'truth'.What I describe about these two entities is not philosophy, but factual and essentially the 'truth'.
Check this definition of philosophy from Wikipedia:
Philosophy is the discipline concerned with questions of how one should live (ethics); what sorts of things exist and what are their essential natures (metaphysics); what counts as genuine knowledge (epistemology); and what are the correct principles of reasoning (logic).[1] [2] The word itself is of Greek origin: φιλοσοφία (philosophía), a compound of φίλος (phílos: friend, or lover) and σοφία (sophía: wisdom).[3][4]
Though no single definition of philosophy is uncontroversial, and the field has historically expanded and changed depending upon what kinds of questions were interesting or relevant in a given era, it is generally agreed that philosophy is a method, rather than a set of claims, propositions, or theories. Its investigations are based upon reason, striving to make no unexamined assumptions and no leaps based on faith or pure analogy. Different philosophers have had varied ideas about the nature of reason, and there is also disagreement about the subject matter of philosophy. Some think that philosophy examines the process of inquiry itself. Others, that there are essentially philosophical propositions which it is the task of philosophy to prove.[5]
All Philosophy may not be true, but the truth remains the truth and thus there is no confusion between all that 'being a pure mathematician or not'
As said when a number is divided by zero, on an extended real line it is equal to infinity, then if you multiply infinity by 0, should it yield the number back?If not, then what is its solution?
Aug31-07, 09:40 AM   #11
Recognitions:
From post 1:
Does that make him an impure mathematician?
Aug31-07, 09:45 AM   #12
Recognitions:
As said when a number is divided by zero, on an extended real line it is equal to zero, then if you multiply infinity by 0, should it yield the number back?If not, then what is its solution?
The problem is not a question of philosophy or mathematics but rather your vague understanding of mathematics. Certainly no one has ever said "when a number is divided by zero, on an extended real line it is equal to zero"! You may have meant "when a number is divided by zero, on an extended real line, it is equal to infinity" but that is not true either. You can extend the real line to include "infinity" (or in a different way to include "positive infinity" and "negative infinity") but that is purely "geometric" and you lose the "algebraic" properties of the real numbers. It makes no sense to talk about either division or multiplication on the extended real number line.
Aug31-07, 09:54 AM   #13
Quote by Hurkyl View Post
Slip of the hand...anyway, then what exactly does any number divided by zero or inifinity yield or what is the product of zero and infinity?
Aug31-07, 09:56 AM   #14
Recognitions:
Quote by HallsofIvy View Post
Huh? Surely we can multiply and divide most elements by analogy with reals when real You still can't divide by zero, and can't multiply infinity by 0, but the rest can be defined in the ordinary way... yes?
Aug31-07, 10:01 AM   #15
I understand that they cannot be defined in an ordinary way...but is there any way we could perhaps define these undefined quantities quantities and find a solution for them?
Thread Closed
Thread Tools
Similar Threads for: Zero and Infinity
Thread Forum Replies
infinity subtracted from infinity is undefined. Linear & Abstract Algebra 46
+ infinity and - infinity join ? General Math 4
A sinusoid integrated from -infinity to infinity Calculus & Beyond Homework 4
Infinity minus Infinity General Math 4
Infinity/Negative Infinity and Zero General Math 5
