How Does String Mass Affect the Motion of Two Connected Blocks?
  • Thread starter Thread starter Mindscrape
    Motion
The discussion focuses on the dynamics of two connected blocks, each of mass M, with a mass m string affecting their motion. The kinetic energy equations are established as T = 1/2 m ˙x² + 1/2 m ˙y², while the potential energy is defined as U = -Mgy + U_{string}. The potential energy contribution from the string is derived from its mass distribution, leading to the conclusion that U_{string} = -m g (y/2) for the hanging portion of the string. This analysis clarifies the relationship between the string's mass and the overall potential energy in the system.
  • Understanding of Hamilton's principle in classical mechanics
  • Familiarity with kinetic and potential energy equations
  • Knowledge of center of mass calculations
  • Basic principles of dynamics involving pulleys and connected masses
  • Study Hamiltonian mechanics for deeper insights into energy conservation
  • Explore potential energy calculations in systems with variable mass distributions
  • Learn about the dynamics of systems involving frictionless pulleys
  • Investigate the effects of varying mass on the motion of connected bodies
Students and professionals in physics, particularly those studying mechanics, as well as educators looking to enhance their understanding of dynamics involving connected masses and energy principles.
Mindscrape
Two blocks, each of mass M, are connected by an extensionless, uniform string of length l. One block is placed on a smooth horizontal surface, and the other block hangs over the side, the string passing over a frictionless pulley. Describe the motion of the system when the string has a mass m.
By Hamilton's principle
[tex]L = T - U[/tex]
the kinetic energies will be
[tex]T = 1/2 m \dot{x}^2 + 1/2 m \dot{y}^2[/tex]
and if the potential is defined to be zero at the horizontal, the potential will be
[tex]U = -Mgy + U_{string}[/tex]
This is the part I need a quick help on. The x block has a zero potential because it stays along the horizontal where the zero potential is defined, and the hanging block will have a potential of -Mgy, and I know that the mass of the string contributing to the potential will increase until finally it reaches as the string moves down. So I was thinking that
[tex]U_{string} = -\frac{m}{t}*g*y[/tex]
That gives the mass per unit time for a given length y, which would also be
[tex]U_{string} = -m g \dot{y}[/tex]
But units don't work out correctly unless I divide U_string by t, which would create a discontinuity and not make any sense. I don't know why I am having so much trouble with such a simple prospect.
Why did you use (m/t)? You should find the center of mass of the part of the string which hangs below the table. If the total mass is m, then the hanging part is
[tex]m'=m\frac{y}{l}[/tex]
and mass center is in the middle (y/2). This information should give you the potential energy of the string.
