New Reply
Can someone please explain simply what happens when you make ripples in a ripple tank
Share Thread Thread Tools
Sep4-07, 05:17 AM   #1
Can someone please explain simply what happens when you make ripples in a ripple tank when there's something (like a piece of wood) in it and WHY it happens??
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep4-07, 10:42 AM   #2
When you drop a stone in a pond, you displace the water on which the stone fell. Imagine the surface of water like a surface of rubber or elastic. The stone drops on this surface, and forms a depression in it. The surface exerts a force back on the stone causing the surface to try and regain its original shape.
Hence, the portion of the surface on which the stone fell starts going up and down (or oscillating). This causes the particles adjacent to the point on which the stone fell to also go up and down. Hence, in this manner, energy is transferred from particle to particle, and the particles on the whole surface start oscillating. Some of these particles go up and down in the same way (ie, when one is up, the other is also up; this is called being in phase) which results in the ripples you see.
The particles themselves do NOT move, they just go up and down in the same place. The force which causes the surface to regain its original shape is called surface tension.
Any questions, just ask.
Nov10-11, 02:31 PM   #3
It's the way the molecules push upon each other within the body of water. When the rock is thrown in, the force created moves the water molecules around the radius of the rock. The force pushes out until enough force from the outside of the ripple pushes inward. You have to remember this is happening all around the radius of where the rock was thrown, so you have a cirular ripple effect from opposite sides of the radius pushing upon each other in opposite forces. Kinda like a circular micro-wave, and any other wave, just in a circle.
New Reply
Thread Tools
Similar Threads for: Can someone please explain simply what happens when you make ripples in a ripple tank
Thread Forum Replies
Mod-11 Ripple Counter Engineering, Comp Sci, & Technology Homework 0
Wavelength of Ripples in a Pond General Physics 10
Bow waves and air Ripples Mechanical Engineering 23
Ripples in the water General Physics 5
Pond Ripples Introductory Physics Homework 0
