Velocity and Momentum: Understanding the Basics
  • Thread starter Thread starter eraemia
    Momentum Velocity
The discussion focuses on fundamental concepts of velocity and momentum in physics. It clarifies that the statement "The car rounded the corner at a constant velocity" is incorrect due to the misuse of the term 'velocity.' The second question regarding upward momentum from a table is debated, with the conclusion leaning towards false if no displacement occurs. For the third question, the impulse experienced by a 1.0 kg cart after colliding with a 3.0 kg cart is calculated as 0.75 kg m/s leftward, emphasizing the importance of understanding momentum and impulse in collisions.
  • Understanding of basic physics concepts such as velocity and momentum.
  • Familiarity with Newton's laws of motion.
  • Knowledge of impulse and its relation to momentum.
  • Ability to perform calculations involving kinetic energy.
  • Study the principles of Newton's laws of motion in detail.
  • Learn about the conservation of momentum in collisions.
  • Explore the relationship between impulse and momentum in various scenarios.
  • Review calculations involving kinetic energy and its implications in physics problems.
Students studying physics, educators teaching basic mechanics, and anyone interested in understanding the principles of velocity and momentum in real-world applications.
eraemia
I have three questions:
1. "The car rounded the corner at a constant velocity." Would this statement make sense to a physicist?
2. A cup sitting on a table constantly receives upward momentum from the table, T or F?
3. Imagine that a 1.0 kg cart traveling rightward at 1.0 m/s hits a 3.0 kg cart at rest. Afterward, the smaller cart is observed to move leftward with a speed of 0.75 m/s. What impulse did the collision give the smaller cart at the expense of the larger?
None
1. No, the word velocity is being used incorrectly.
2. I don't know about this one. I would say true, if the compression contact interaction of the table can be considered as velocity (which is a component of momentum). False, if the table is not displacing anything, hence there is no displacement over time or velocity.
3. I don't understand the question. The collision gave the smaller car an impulse? Well, I suppose 0.75 kg m/s leftward? Or was there none?
1, correct
2, No momentum and force are quite different.
3, Impulse is force * time so has units of Newton seconds ( or kg m/s )
I don't see how part 3 can be true, the initial carts has ke = 0.5 * 1 * 1^2 = 0.5J
the second cart has ke = 0.5 * 3* 0.75^2 = 0.84J unless I have made a msitake in arithmetic.
For part 3, impulse given to the small cart is change in momentum of the small cart... so the final momentum of the small cart - initial momentum of the small cart is what you need... careful about directions and signs.
  • · Replies 40 ·
  • · Replies 24 ·
