Advice on Exponential, Binomial, & Normal Distributions
The discussion revolves around various probability distributions, specifically exponential, normal, binomial, and Poisson distributions. Participants are seeking clarification on specific problems related to these distributions, including calculations and interpretations of results.
  • Homework-related
  • Participant NW poses several questions regarding the exponential distribution, specifically the probability of a call arriving within 15 minutes, and presents a calculated probability of 0.98347.
  • In the context of the normal distribution, NW questions the proportion of trucks expected to travel between 34.0 and 38.0 thousand km, providing a calculated estimate of around 6.64% but expressing uncertainty due to a different result obtained from a computer.
  • NW also seeks clarification on how to determine the distance traveled by at least 80% of the trucks, suggesting a preference for focusing on the 20% value.
  • For the binomial distribution, NW calculates the probability of getting five questions correct as 1/1024 and at least four questions correct as 5/1024, indicating confidence in these answers.
  • In the Poisson distribution context, NW estimates the probability of exactly one network error occurring as approximately 21.7% and two or more errors as around 78%, but seeks confirmation on these calculations.
  • Another participant questions NW's understanding of the normal distribution problem, suggesting that a two-sided test should be considered for the 80% calculation.
  • Further clarification is provided regarding the standardization of values for the normal distribution and the interpretation of cumulative probabilities.
Participants express varying levels of confidence in their calculations and interpretations, with some seeking further clarification on specific points. There is no consensus on the correct answers to the posed questions, and multiple interpretations of the problems are present.
Participants' calculations depend on their understanding of the distributions and the assumptions made in their approaches. There are unresolved aspects regarding the interpretation of the normal distribution problem and the application of cumulative probabilities.
NW8800
Hey,
I'm new to all this so cut me some slack, but have been trying to work through some questions, and I can't seem to find answers to these questions... Or atleast find the confidence that my answers/working is correct...
1. (Exponential Distribution) Telephone calls arrive at the information desk of a large
computer software company at the rate of 15 per hour.
What is the probability that the next call will arrive within 15 minutes?
(What would eb the formula for this one?) I got 0.98347
2. (Normal Distribution) For a group of trucks, it was found on an annual basis that the distance traveled per truck is normally distributed with a mean of 50.0 thousand km and a standard deviation of 12.0 thousand km.
(i) What proportion of trucks can be expected to travel between 34.0 and 38.0
thousand km in the year?
I get around 6.64%, but I am not sure that I am doing it right as I tried to do the same thing on the computer and I get something like 6.674438...
(ii) How many km will be traveled by at least 80% of the trucks?
(This one really has me stumpted as I am not sure if it means I look at the normal distro curve, and sort of 40% on each side or, do I try and figure out the 20% value there, and say that at least 80% of the trucks travel >than that distance. The latter makes more sense to me...) I tried the latter and I got 39,920km
3. (Binomial Distribution) A student is taking a multiple-choice exam in which each
question has four choices.
Assuming that he/she has no knowledge of the correct answers to any of the questions, he decided on a strategy in which he will place four balls (marked A, B, C and D) into a box.
He randomly selects one ball (with replacement)for each question. The marking on the ball will determine hisanswer to the question.
There are five multiple-choice questions on the exam. What is the probability the he will get:
(i) five questions correct?
(ii) at least four questions correct?
I think i have this one sorted now, i)=1/1024 ii)=5/1024
4. (Poisson Distribution) Assume that the number of network errors experienced in a day on
a local area network (LAN) is distributed as a Poisson random variable. The average
number of network errors experienced in a day is 2.4. What is the probability that in any
given day
(i) exactly one network error will occur?
(ii) two or more network errors will occur?
i) This one I get ~21.7%
ii) I did 1-P(X=2) = ~78%
Any help please?
Thanks,
NW
You are doing a 2-sided test, so you need 10% on each side.
For 4.(ii), 1-P(X=2) is the probability that X is not 2. Is that what you wanted?
It would help if you describe how you got each answer.
Hey,
Thanks for your reply!
I seem to have it all sorted cept for question 2:
Could you explain a little more about this one...
(i) is the probability {34 < X < 38}. Do you know how to standardize the 34 and the 38 (turning them into a z score each)? Once you have that, you'd just need to look it up in a normal probability table.
(ii) is the answer to Prob{Z < z} = 0.8 solved for the little z. If F is the cumulative normal distribution so that F(z) = Prob{Z < z}, F(z) = 0.8 solved for z is your answer. Again, you can look up which value of z satisfies this from a normal probability table. Most probability tables assume a two-sided test, but you are running a one-sided test. So you need to look for the z value that leaves 0.2 probability "to the right." In a two-sided test, that z value will be stated as the z value corresponding to a 0.4 tail probability (0.2 to the left of -z, 0.2 to the right of +z). You are concerned only about the +z.
  • · Replies 24 ·
