Twin Paradox: Solving for Time Interval in Satellite Orbit | Special Relativity
The problem involves a clock in a satellite orbiting Earth for 5400 seconds and seeks to determine the time interval difference between this clock and an identical clock on Earth after one year, applying concepts from special relativity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the speed of the satellite, with some suggesting it should be based on escape velocity while others argue that escape velocity is not relevant for an orbiting satellite. There are attempts to derive the satellite's velocity using gravitational and centripetal force equations, and questions arise about the necessary altitude for accurate calculations.
The discussion is ongoing, with participants exploring different interpretations of the problem and attempting to clarify the necessary parameters for calculations. Some guidance has been offered regarding the use of Taylor expansion for small velocities, but no consensus has been reached on the calculations or assumptions made.
Participants note the lack of information regarding the altitude of the satellite, which complicates the calculation of its velocity. There is also mention of the potential limitations of calculators in approximating gamma for small velocities.
Benzoate
A clock is placed in a satellite that orbits Earth for a period of 5400 seconds. By what time interval will this clock differ from an identical clock on Earth after 1 year(assume that special relativity applies.)
v(escape velocity)=11186 m/s
possibly delta(t) = delta(t')/gamma
gamma =1/sqrt(1-v^2/c^2)
First I converted 1 year => 31536000 s
after 1 year , the observers on the satelitte measured the new time of the sattilitte to be
t(new)= 31536000 seconds + 5400 seconds = 31541400 seconds
after 1 year , the observers measured the Earth notices that the velocity of the satelitte to approach the speed of light.
t'(new) = 31536000 seconds + 5400 seconds/gamma=31541400.000004
the time interval between the times measured on Earth and on the satelitte after 1 year = 31541400 seconds -31541400.000004=.000004 seconds
but the back of my books says 9.6 ms. Where did I go wrong ?
What's the speed of the satellite?
It does explicity state the speed of the satellite in the problem . But I assumed the escape velocity for all objects leaving the Earth is about 11186 m/s , according to the list of physical constants in the appendix of my textbooks.
Does? Or does not? If not, you have to figure it out.
What's escape velocity have to do with it? It's orbiting the earth, not escaping.
It doesn't. wouldn't the velocity be v=2*Pi*(R(earth))/1 year?
Only if its altitude is zero. Read this: Earth Orbits
so then finding the velocity of the orbit would be pointless if we are not given the distance between the Earth and sattelite
Set the gravitational force equal to centripetal force... ie:
GMm/r^2 = mv^2/r
GM/r^2 = v^2/r
using this equation and
v = 2pir/5400
You can solve for v... you have 2 equations 2 unknowns (v and r).
GMm/r^2 = mv^2/r
GM/r^2 = v^2/r
v = 2pir/5400
Isn't r just the sum of the Radius of the Earth + the altitude of the satelitte?
r=R(earth) + h
r=R(earth) + h
Yes. But you don't know the altitude.
I understand how calculate the velocity but for some reason I came up with the same time interval
I'll take you through my calculations.
GM(earth)/r^2 = v^2/r => v=sqrt(G*M(earth)/r) = 2*Pi*r/T
G*M(earth)/r = 4*pi^2 *r^2 /(5400s)^2 => r^3 = ((5400s)^2/(4*pi^2))*(6.67e-11)*(5.97e24 kg) => r= 6650321.521 m
now I can find the velocity: v =2*pi*(6650321.521 m)/(5400 s) = 7738 m/s
1 year = 31536000 seconds as measured by the person on the satellite
the time measured by the observer on Earth is gamma*proper time = 31536000 seconds*(1/(sqrt(1-(7738 m)^2/c^2) =3153600seconds
so there is no time differences according to my calculations. What am I doing wrong ?
Since the speed is so small compared to light speed, the time difference won't be much. You won't be able to find it by plugging the numbers directly into a (typical) calculator, since 1 minus a tiny number will show up as 1. Instead, use a Taylor expansion of gamma for small v/c to calculate the time difference.
But are my equations and calculations are correct
You think a TI -83 or TI-89 would approximate gamma better than a mere scientific calculator?
You work looks OK to me. I don't know anything about those calculators, but I doubt they'll do any different. Do the Taylor expansion--that's the easy way.
  • · Replies 43 ·
  • · Replies 17 ·
  • · Replies 70 ·
  • · Replies 115 ·
10K
