Standing waves and length of tube
The discussion revolves around determining the length of a tube that supports standing waves at specific frequencies: 390 Hz, 520 Hz, and 650 Hz. The context involves understanding wave behavior in a narrow column of air, particularly in relation to the properties of open and closed tubes.
  • Participants discuss the type of tube (open or closed) and its impact on the frequencies observed. There are questions about the calculations of corresponding mode numbers (m) for each frequency and how different speeds of sound might affect the length of the tube. Some participants express confusion about the relationship between frequency and tube length.
Participants are actively exploring the relationships between the frequencies and the tube length, with some suggesting that the fundamental frequency can be derived from the given frequencies. There is a recognition that different interpretations of the tube's configuration may lead to different conclusions about the length.
There is uncertainty regarding the specific setup of the tube (one-end open vs. both ends open) and how this affects the standing wave patterns. Some participants mention varying speeds of sound and their influence on the calculations, indicating a need for clarity on these assumptions.
aliaze1
A narrow column of air is found to have standing waves at frequencies of 390 Hz, 520 Hz, and 650 Hz and at no frequencies in between these. The behavior of the tube at frequencies less than 390 Hz or greater than 650 Hz is not known.
How long is the tube?
f = m(v/(2L)) = mf
m = 1,2,3,4...
I keep getting .4358 or .4410 (depending on if I use 344 or 340 for the speed of sound, respectivly)
one-end open tube or both ends open tube?
btw, your answers seem wrong either
open on both ends, basically like a pipe..
aliaze1 said:
f = m(v/(2L)) = mf
m = 1,2,3,4...
did u work out the corresponding m's for your frequencies? indeed, different wave speed will give different L.
huh?
so each frequency will give a different length? so what length would be correct?
well it said 'narrow column of air' so i assumed open on both ends
no, what I meant was, you should work out the value of your m's corresponding to each frequency:
say [tex]m_{f1} = k, m_{f2}=k+1, m_{f3}=k+2[/tex] where f1, f2 and f3 are the 390, 520, 650 Hz.
and you would only get different answer if your speed of sound is different.
it appears that this can only be the open-both-ends case for it to work. (just from the wavelength to m relations)
Um, I'm not sure on this question either. Can someone guide me through it? It's also been giving me problems.
Hate to revive an old thread but I can't figure out this one for the life of me...I've tried entering the length for every frequency (with the accompanying mode) and none of them seem to give me the correct length.
Three frequencies 390, 520, and 650 Hz can be wrightten as 3x130, 4x130 and 5x130. The same open tube can resonate in these three modes. Hence fundamental resonant frequency of the tube must be 130 Hz. Using this frequency and the velocity of sound, you can calculate the length of the tube.
  • · Replies 19 ·
