Integration, u substitution, 1/u
The discussion revolves around integration techniques, specifically focusing on the use of u-substitution in integrals involving the function 1/u. Participants are examining two integrals: one involving the expression 1/(8-4x) and the other 1/(2x).
  • Mixed
  • Participants explore different methods of integrating the given functions, discussing the implications of pulling out constants in the integration process. There are questions about the validity of different approaches and the resulting expressions from u-substitution.
There is an ongoing exploration of the integration techniques, with participants providing various interpretations and suggestions. Some express confusion over the necessity of pulling out constants in certain cases, while others clarify their reasoning. No explicit consensus has been reached regarding the best approach.
Participants are also discussing the formatting of their mathematical expressions, indicating a potential barrier to clear communication. There are mentions of algebraic manipulation and the impact of constants on the final answers, which remain points of contention.
Gibybo
[SOLVED] Integration, u substitution, 1/u
-- +C at the end of the integral solutions, I can't seem to add it in the LaTeX thing --
#1 [tex]\int\frac{1}{8-4x}dx[/tex]
#2 [tex]\int\frac{1}{2x}dx[/tex]
Rewrite algebraically:
[tex]\int\frac{1}{x-2}*\frac{-1}{4}dx[/tex]
Pull out constant:
[tex]\frac{-1}{4}\int\frac{1}{x-2}dx[/tex]
Usub, u=x-2, du=1*dx,
[tex]\frac{-1}{4}\int\frac{1}{u}du[/tex]
[tex]\frac{-ln(u)}{4}[/tex] -> Answer: [tex]\frac{-ln(x-2)}{4}[/tex]
#2
Pull out constant: [tex]\frac{1}{2}*\int\frac{1}{x}dx[/tex]
Answer: [tex]\frac{ln(x)}{2}[/tex]
--OR, if I don't pull out constants--
#1
Usub, u=8-4x, du=-4dx,
[tex]\frac{-1}{4}*\int\frac{1}{u}du[/tex]
[tex]\frac{-ln(u)}{4}[/tex] -> Answer: [tex]\frac{-ln(8-4x)}{4}[/tex], which =/= [tex]\frac{-ln(x-2)}{4}[/tex]
#2
Usub, u=2x, du = 2dx,
[tex]\frac{1}{2}[/tex][tex]\int\frac{1}{u}du[/tex]
[tex]\frac{ln(u)}{2}[/tex] -> Answer: [tex]\frac{ln(2x)}{2}[/tex], which =/= [tex]\frac{ln(x)}{2}[/tex]
I know the answers are -1/4*ln(8-4x) and ln(x)/2 respectively, but I don't understand why I cannot pull out the constant for the first one, yet I am required to pull it out for the second?
Bonus question: Why does my TI-89 integrate #1 incorrectly, but #2 correctly? :(
(8-4x),x ... did you mean dx? because I'm confused.
#2 is correct for sure, let me go back to # 1.
i'm getting dizzy reading your text but from what i see, your algebra-manipulation should have been for #1
[tex]\frac{1}{4}\int\frac{1}{2-x}[/tex]
Yeah, by integrate(4x,x) I would mean 4x*dx. It's standard notation when typing integrals for calculators/CAS's etc, I did it that way because I was thinking the forums might automatically convert it to the proper mathematical symbols.
oh sorry, i did not know that! :)
Ah hah, that's how you make it pretty!
Anyway yeah, I have [tex]\frac{-1}{4}\int\frac{1}{x-2}[/tex]
which is equivalent and still valid, right?
Introducing LaTeX Math Typesetting - https://www.physicsforums.com/showthread.php?t=8997 it gets addicting!
yep, don't forget + C ;) .. -1 or maybe the whole problem will be counted wrong, lol :D
when you do your final integrations the ln shouldn't be in the denominator of the fraction.
It's (-1/4)*(lnx-2)+c which gives -ln(x-2)/4 + C the same goes for the second one.
Oh sorry, just an error while converting to [tex]images I think.<br /> <br /> -ln(x-2)/4+c is incorrect though, which is my problem.[/tex]
I'm not sure why you pulled the constant out in the first place. I would go u = 8-4x du= -4dx and then write (-1/4)*integral 1/u du.
Integrate and get (-1/4)ln(8-4x)
the second one I would make u = 2x du = 2dx and then write the integral as 1/2 * integral 1/u * du and the integrate and get (1/2) ln (2x)
Right, I did both of them both ways. If you do not pull out the constants, you get the correct answer for #1. However, #2 is not (1/2)*ln(2x), it is ln(x)/2.
Summary:
Pull out constants:
#1 wrong, #2 right
Do NOT pull out constants:
#1 right, #2 wrong
there really is no benefit in simplifying this problem, i would just go at what you're given.
I'm not sure what you're saying. I shouldn't pull out constants?
Why is it wrong to pull them out then?
And how do you correctly do #2 without pulling out constants first?
for 1, integrate by u subst., but 2 you have to pull out the constant.
i just don't see a point in pulling out a constant for 1 b/c you run the risk of making algebraic mistakes, that's all really.
I agree, but why is it wrong when I do? I think we can agree that there are no algebraic mistakes there. Why do I HAVE to pull them out for #2?
ln(2x) = ln(x) + ln(2) = ln(x) + C, with C = ln(2). Since indefinite integrals are only defined up to an additive constant, your two answers are the same. This is true for both problems.
Ah hah! Thanks :) [hits self on head]
You're welcome! :) (It's always the little things that cause trouble ...)
  • · Replies 105 ·
13K
  • · Replies 22 ·
