Where is the energy when two photons superimpose?
  • Context: Graduate
  • Thread starter Thread starter flame_cmh
    Energy Photons
The discussion revolves around the behavior of energy in a system of two photons superimposing, particularly when they propagate in opposite directions. Participants explore concepts related to superposition, polarization, and the implications of classical and quantum mechanics on wave behavior.
  • One participant suggests that when two photons coincide in position, the energy appears to disappear due to the principle of superposition, questioning the implications of this phenomenon.
  • Another participant counters that the initial proposition violates the Heisenberg uncertainty principle, explaining that photons cannot have perfectly defined positions and trajectories, and discusses the concept of standing waves formed by counter-propagating plane waves.
  • A participant expresses confusion about the implications of unpolarized light, suggesting that if the electric field oscillates in all directions, the resultant field might be zero, and seeks clarification on this point.
  • In response, another participant clarifies that while the probability of polarization is equal in all directions for unpolarized light, this does not mean the resultant field is zero, emphasizing the role of the source in determining wave characteristics.
  • One participant raises concerns about the practicality of achieving complete destructive interference due to various boundary conditions and external factors.
  • Another participant questions whether using photons is appropriate for discussing wave interference, suggesting that mechanical and classical electromagnetic waves might be more suitable for exploring energy transmission and cancellation.
  • A participant notes that two counter-propagating waves create a standing wave, emphasizing that cancellation can only occur under specific conditions and discussing the implications for energy conservation.
Participants express multiple competing views regarding the behavior of photons and waves, particularly concerning superposition, polarization, and energy transmission. The discussion remains unresolved with no consensus reached on the implications of these concepts.
Participants acknowledge limitations related to ideal boundary conditions, the nature of wave interactions, and the complexities of quantum mechanics versus classical interpretations.
flame_cmh
Suppose that two photons are the same and propagation in opposite direction in vacuum, the energy of this system of course is 2h*[tex]\nu[/tex].
When they coincide in position, according to the principle of superposition there is no electric and magnetic field, then the energy disappear at that time??
Science news on Phys.org
Your proposition is flawed, as it violates the Heisenberg uncertainty principle. You can't get photons that have perfectly defined position and trajectory. Photons with a perfectly defined trajectory must have an uncertainty in their wavevector direction of zero, which implies that the wavefunction of the photon is an infinite plane wave. Since the wavefunction is infinite in extent, the uncertainty in position is infinite.
Nonetheless one could in theory add two infinite counter-propagating plane waves, in which case one gets a standing wave. You will get points (nodes) where the probability of finding a photon is exactly 0, however the total energy of the system will of course continue to be 2hv.
Claude.
Ok, I get it, and thanks!
Maybe that's why it takes so long to get a reply on the thread, cause I asked a stupid question!^_^
This question originally came out from that I read the lectures of Feynman on polarization of the light! So I think if a source shot out a unpolarized light, according to the classical interpretation of light, the electric field amplitude probabily in any direction perpendicular to the direction of propagation. And when the light arrive at a point say P, the resultant field is always zero, cause it is no reason that the oscillates of the field is perfer certain direction, so the propability of the oscillation in all direction should be a constant.
And if that's right, since the field is zero, we can't see anything. Of cause it's wrong, but I don't know where, that's what I need you to tell me.
Forgive my bad chinglish!
If I understand your question correctly - For an unpolarised beam, the probability of a photon being polarised in a particular direction will be equal for all directions - but this does not imply that the resultant field ought to be zero.
Classically, the direction of oscillation is completely determined by the source. In order to generate a wave, you need to wiggle a charge - the direction you wiggle the charge will determine the polarisation of the generated wave. So you never get perfect symmetry because you need to consider how the wave is generated in the first place. A classical unpolarised beam is a statistical entity, the sum product of many-many small, polarised components.
Quantum Mechanically, a photon can exist in a superposition of polarisation states. A photon emitted via spontaneous emission usually has no preferred direction or polarisation, but this just implies that the probabilities of the emitted photon possessing a particular polarisation are equal - this is sufficient to preserve symmetry as there is still no preferred direction. In the Quantum world, one can get a truly unpolarised wave.
P.S. These questions aren't stupid - I think they are quite thought-provoking.
Claude.
I understand you, and thanks for your time!
Boundary conditions are never ideal, and thus complete destructive interference involving boundaries of finite distance and mass, gravitational (including parallelism) and E-M forces, thermal effects and material composition is impractical.
I still have something uncertain about this, and I think for this question better not use photon for instance. Discussing it with mechanical waves and classical E-M waves would be more approprite. If two waves meet together, would they be completely neutralized if their phases are opposite? And then there is no wave, and how does the energy transmit? By what? And where does it exist? How far will it utimatly come out? Is it just that the boundary is not suitable for this discussion?
Two counter-propagating waves sum to produce a standing wave. This result is well known.
Two waves can only cancel for all time if they are colinear to begin with, for example from two parallel reflecting surfaces. The effect of this is also well-known, it results in the suppression of radiation. The implication of this is that you can't emit a wave then cancel it at a later time, you can only prevent the wave from being emitted to begin with, which results in the law of conservation of energy being upheld.
Claude.
  • · Replies 26 ·
  • · Replies 21 ·
